vic20 Posted May 21, 2005 Posted May 21, 2005 Does this card work with DVBViewer: http://www.twinhan.com/product_terrestrial_4.asp ? Quote
hackbart Posted May 22, 2005 Posted May 22, 2005 Good question, probably - i just implemented -c and -t theoreticly, but at least -c runs Christian Quote
chimen Posted May 23, 2005 Posted May 23, 2005 (edited) I have tested the twinhan dvb-T card. It kind of works. But somehow it depends on the original Twinhan software. If I have watched a channel at a certain frequency on the original twinhan software (twinhan dtv) then I can use DVBViewer with that frequency. I can scan for channels and watch the channels I find. But only at that frequency. After that I reformated my harddrive and reinstalled windows xp and installed only the drivers for the card, not the twinhan software, and then installed DVBViewer. Now I can't find any channel when I scan. Why is it that I first have to use Twinhan DTV to be able to use the card in DVBViewer?? Great program except for this problem!!! Edit: Now i can confirm that DVBViewer also works with paychannels and CA-moduls on twinhan dvb-t CI. I still have the problem with scanning diffrent frequencys tough. Please help! Edited May 27, 2005 by chimen Quote
moremetall Posted May 24, 2005 Posted May 24, 2005 Hi chimen! I have the same problem as you when I tested it ... when I did scan I cant find any of the free channels ..and some of the paychannels ... Kind regards Micael Quote
