malle100 Posted April 3, 2025 Posted April 3, 2025 Hey is it possible to set up multicast so I can send out multiple channels UDP on one IP, with different ports or on different IPs? End in DVBViewer or DVBview server? Quote
Griga Posted April 3, 2025 Posted April 3, 2025 4 hours ago, malle100 said: is it possible to set up multicast so I can send out multiple channels UDP on one IP, with different ports Yes, with the DVBViewer Media Server. This feature requires a special licence for professional purpose, though. Please read more about it here in the section that begins with Quote Added: API/RTSP Server: Possibility to configure permanent UDP/RTP unicast and multicast streams (running independently from client access). Please note that this feature requires an extended license that allows for at least 50 Media Server clients at the same time.... If you want to buy such a licence, please contact the mail address given under the "Contact Us" link at the bottom of the forum. Quote
malle100 Posted April 14, 2025 Author Posted April 14, 2025 On 4/3/2025 at 6:30 PM, Griga said: Yes, with the DVBViewer Media Server. This feature requires a special licence for professional purpose, though. Please read more about it here in the section that begins with If you want to buy such a licence, please contact the mail address given under the "Contact Us" link at the bottom of the forum. I have created 4 RTPS servers, each with its own IP. How do I choose which channels to send to that IP? I just need to be able to send 5 channels at the same time, each with its own IP? Quote
Griga Posted April 15, 2025 Posted April 15, 2025 12 hours ago, malle100 said: I have created 4 RTPS servers, each with its own IP. How do I choose which channels to send to that IP? This is the wrong approach. Here I have already provided a link to multicast setup instructions, but obviously you didn't read or didn't understand them. So let's start from the beginning: Basic Media Server Multicast Setup Make sure that the DVBViewer Media Server is running. Open a browser on the server PC (!) and enter an address like this in the address bar (just an example): http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&chid=2359890582721931325|Das Erste HD The meaning of the different parts: The blue part is the address of the Media Server's web server that receives your setup command. /rtp/ means that a udp/rtp stream shall be set up. The Media Server will encapsulate the DVB transport stream in the RTP protocol and the resulting RTP stream in the UDP protocol. Sat>IP does it in the same way. The green part indicates the address and port of the stream. Please note that the IP address must be within the multicast address range 224.0.0.0 to 239.255.255.255. Otherwise you will get Unicast. The red part specifies the ID of the channel that shall be sent. In the example above it is the ID of the German channel "Das Erste HD" via the Astra satellite. You will probably want another channel ID. You can obtain it from the DVBViewer channel editor. Open it, right-click the desired channel, select "Copy ID to Clipboard" and insert it in your setup command. After entering the setup command in the browser's address bar just hit the Return key. If you get no error message, the stream is up and running. It is recommendable to store the command as bookmark in the browser, so you can use it again later. Please note the following points: Sending the same command again lets the Media Server stop the stream, if it is running. A multicast stream is running and distributed in your network, no matter whether a client is receiving it or not. A multicast stream can be received by multiple clients at the same time, provided the network capacity is sufficient. All components in your network must be able to to handle multicast properly. If not, you may experience problems, e.g. a network overload. If you want to set up another stream with another channel, you must modify the multicast IP address (e.g. to 239.0.0.2) and/or the port (e.g. to 5019) and the channel ID, of course. Modifying the port and channel ID is usually sufficient. How to Receive and Test a Multicast Stream in Clients: Just enter the address rtp://239.0.0.1:5018 (example) in a client that is able to process such streams, e.g. in VLC (Media -> Open Network Stream) or DVBViewer, where you can include the stream in the channel list: Open the channel editor. Select the folder or location where the stream shall be inserted. Click the "New" button at the bottom. Select "Stream" in the popup menu. Enter the address rtp://239.0.0.1:5018 (example) in the Address input line and the channel name in the Name input line. Don't care about the other data. DVBViewer will detect it automatically on first playback start. Start playback of the new channel list entry by double-clicking it. If you are dealing with more than one multicast stream, it is recommendable to create a list of the addresses as M3U playlist file for easier handling. M3U is a text file with the file extension .m3u. Its content may look like this (example): #EXTM3U #EXTINF:-1,Das Erste HD rtp://239.0.0.1:5018 #EXTINF:-1,ZDF HD rtp://239.0.0.1:5019 #EXTINF:-1,3sat HD rtp://239.0.0.1:5020 ... ...and so on. Such an M3U file can easily be imported in VLC or DVBViewer. For including the contained channels in the DVBViewer channel list, just drag and drop the M3U file into the DVBViewer channel list editor. Please note that the method described above is not Sat>IP, but just simple UDP/RTP multicast streaming. That's for a start... there are additional options for special requirements. We will deal with it as needed. Quote
malle100 Posted April 15, 2025 Author Posted April 15, 2025 (edited) 13 hours ago, Griga said: This is the wrong approach. Here I have already provided a link to multicast setup instructions, but obviously you didn't read or didn't understand them. So let's start from the beginning: Basic Media Server Multicast Setup Make sure that the DVBViewer Media Server is running. Open a browser on the server PC (!) and enter an address like this in the address bar (just an example): http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&chid=2359890582721931325|Das Erste HD The meaning of the different parts: The blue part is the address of the Media Server's web server that receives your setup command. /rtp/ means that a udp/rtp stream shall be set up. The Media Server will encapsulate the DVB transport stream in the RTP protocol and the resulting RTP stream in the UDP protocol. Sat>IP does it in the same way. The green part indicates the address and port of the stream. Please note that the IP address must be within the multicast address range 224.0.0.0 to 239.255.255.255. Otherwise you will get Unicast. The red part specifies the ID of the channel that shall be sent. In the example above it is the ID of the German channel "Das Erste HD" via the Astra satellite. You will probably want another channel ID. You can obtain it from the DVBViewer channel editor. Open it, right-click the desired channel, select "Copy ID to Clipboard" and insert it in your setup command. After entering the setup command in the browser's address bar just hit the Return key. If you get no error message, the stream is up and running. It is recommendable to store the command as bookmark in the browser, so you can use it again later. Please note the following points: Sending the same command again lets the Media Server stop the stream, if it is running. A multicast stream is running and distributed in your network, no matter whether a client is receiving it or not. A multicast stream can be received by multiple clients at the same time, provided the network capacity is sufficient. All components in your network must be able to to handle multicast properly. If not, you may experience problems, e.g. a network overload. If you want to set up another stream with another channel, you must modify the multicast IP address (e.g. to 239.0.0.2) and/or the port (e.g. to 5019) and the channel ID, of course. Modifying the port and channel ID is usually sufficient. How to Receive and Test a Multicast Stream in Clients: Just enter the address rtp://239.0.0.1:5018 (example) in a client that is able to process such streams, e.g. in VLC (Media -> Open Network Stream) or DVBViewer, where you can include the stream in the channel list: Open the channel editor. Select the folder or location where the stream shall be inserted. Click the "New" button at the bottom. Select "Stream" in the popup menu. Enter the address rtp://239.0.0.1:5018 (example) in the Address input line and the channel name in the Name input line. Don't care about the other data. DVBViewer will detect it automatically on first playback start. Start playback of the new channel list entry by double-clicking it. If you are dealing with more than one multicast stream, it is recommendable to create a list of the addresses as M3U playlist file for easier handling. M3U is a text file with the file extension .m3u. Its content may look like this (example): #EXTM3U #EXTINF:-1,Das Erste HD rtp://239.0.0.1:5018 #EXTINF:-1,ZDF HD rtp://239.0.0.1:5019 #EXTINF:-1,3sat HD rtp://239.0.0.1:5020 ... ...and so on. Such an M3U file can easily be imported in VLC or DVBViewer. For including the contained channels in the DVBViewer channel list, just drag and drop the M3U file into the DVBViewer channel list editor. Please note that the method described above is not Sat>IP, but just simple UDP/RTP multicast streaming. That's for a start... there are additional options for special requirements. We will deal with it as needed. Thank you very much. but i can only do 3 streams then it gives error. has 4 tuners in the TV card. 239.0.0.2:5019 to 239.0.0.4:5021 is fine. Edited April 15, 2025 by malle100 Quote
Griga Posted April 15, 2025 Posted April 15, 2025 2 minutes ago, malle100 said: but i can only do 3 streams then it gives error. Which error? Quote
malle100 Posted April 15, 2025 Author Posted April 15, 2025 4 minutes ago, Griga said: Which error? Bad request in browser, I have try many different ip, ports and channels ID Quote
Griga Posted April 15, 2025 Posted April 15, 2025 There are several possible reasons for it. Please create and attach a support.zip here. It will be helpful to find out what's going on. Quote
Griga Posted April 16, 2025 Posted April 16, 2025 P.S. Please also check the Status page of the Media Server's web interface. It shows the tuner occupation (each tuner with a signal strength indication is busy) and how many streams are currently running. The "400 bad request" error may appear if no tuner is available for the requested stream, or with other words, if all tuners are occupied. Maybe there is a "forgotten" stream that keeps a tuner busy. For clearing all streams, just stop and restart the media server. Quote
malle100 Posted April 16, 2025 Author Posted April 16, 2025 (edited) 2 hours ago, Griga said: P.S. Please also check the Status page of the Media Server's web interface. It shows the tuner occupation (each tuner with a signal strength indication is busy) and how many streams are currently running. The "400 bad request" error may appear if no tuner is available for the requested stream, or with other words, if all tuners are occupied. Maybe there is a "forgotten" stream that keeps a tuner busy. For clearing all streams, just stop and restart the media server. Edited April 16, 2025 by malle100 Quote
malle100 Posted April 16, 2025 Author Posted April 16, 2025 13 hours ago, Griga said: There are several possible reasons for it. Please create and attach a support.zip here. It will be helpful to find out what's going on. support.zip Quote
Griga Posted April 16, 2025 Posted April 16, 2025 The Channel Groups configuration of your Digital Devices DVB-C Tuners seems to cause the problem. The default setting is all groups checked. Why did you restrict it to a single channel group per DVB-C Tuner in the Media Server Options -> Hardware? Channel groups are only useful in very special situations. If you have no special reason for changing the channel groups default configuration, don't touch it! In your configuration the only DVB-C tuner that is allowed to handle channels belonging to group A is Digital Devices DVB-C Tuner 1 (8). So you only have a single DVB-C tuner for streaming channels belonging to group A! As soon as you try to set up a second stream with a second channel belonging to group A, but from a different frequency, you need a second tuner that can handle it. You get failure, because there is none. Quote
malle100 Posted April 16, 2025 Author Posted April 16, 2025 8 hours ago, Griga said: The Channel Groups configuration of your Digital Devices DVB-C Tuners seems to cause the problem. The default setting is all groups checked. Why did you restrict it to a single channel group per DVB-C Tuner in the Media Server Options -> Hardware? Channel groups are only useful in very special situations. If you have no special reason for changing the channel groups default configuration, don't touch it! In your configuration the only DVB-C tuner that is allowed to handle channels belonging to group A is Digital Devices DVB-C Tuner 1 (8). So you only have a single DVB-C tuner for streaming channels belonging to group A! As soon as you try to set up a second stream with a second channel belonging to group A, but from a different frequency, you need a second tuner that can handle it. You get failure, because there is none. It works now, sorry I had changed it. Very good support A few questions - after restarting the PC, shouldn't the streams be able to start up themselves or should it be done manually? - can see some of the streams stop even after about 15 min and do not start again. - how with Encrypted channels, CI modules can be automatically updated, just like on a TV. - has 2 lan connections in PC and has under WEB, set the one IP as "DO not use" does this mean that no Streams are sent outside on the entered IP? Quote
Griga Posted April 17, 2025 Posted April 17, 2025 9 hours ago, malle100 said: - after restarting the PC, shouldn't the streams be able to start up themselves or should it be done manually? It must be done manually. That's why I have proposed to store the setup commands as bookmarks in your browser. However, I think there should be a mechanism that starts multicast streams automatically on Media Server start. For example a list of the multicast setup commands in a text file, that is read by the Media Server on start. Additionally there should be a setup command that stops all multicast streams without having to stop the Media Server. I will try to add something like this as soon as I find time for it. 9 hours ago, malle100 said: - can see some of the streams stop even after about 15 min and do not start again. I don't know why this happens. Maybe a network issue? If this happens again, please tell me the time when it happened and attach another support.zip, so I can check in the svcdebug.log if there was something special going on at this time. 9 hours ago, malle100 said: - how with Encrypted channels, CI modules can be automatically updated, just like on a TV. The Media Server can't update CI modules or CAMs, because there is no API (Application Programming Interface) for it. Maybe it can be triggered manually in the TV/Radio -> CAM menu displayed by DVBViewer. 9 hours ago, malle100 said: has 2 lan connections in PC and has under WEB, set the one IP as "DO not use" does this mean that no Streams are sent outside on the entered IP? There is no "Do not use" setting that applies to the RTP multicast server (only for the web server and the UPnP server). However, you can use a multicast setup command parameter for specifying the IP address of the network adapter that shall be used for sending multicast, like the violet part in the following example (nic = Network Interface Card): http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&nic=192.168.54.100&chid=2359890582721931325|Das Erste HD Quote
Griga Posted April 19, 2025 Posted April 19, 2025 On 4/16/2025 at 10:45 PM, malle100 said: - after restarting the PC, shouldn't the streams be able to start up themselves or should it be done manually? Here is a solution for starting/stopping the streams all at once and also automatically, if required. You can use a batch file and the command line tool cURL that is part of Windows since Windows 10. Create a text file with a content like this (example): rem Das Erste HD curl "http://127.0.0.1:8089/rtp/?ip=239.0.0.3&port=5018&chid=2359890582721931325" rem ZDF HD curl "http://127.0.0.1:8089/rtp/?ip=239.0.0.3&port=5018&chid=2359890548428909414" rem arte HD curl "http://127.0.0.1:8089/rtp/?ip=239.0.0.3&port=5018&chid=2359890582722586686" pause and save it for example as Multicast.bat. Double-clicking the batch file executes all the contained commands one after the other, which means, it lets cURL send the commands to the Media Server. You can read more about cURL here and here. Please note the following important points: The URLs must be enclosed in double quote characters ("....") I have omitted the channel names in the URLs and only added them as comments (rem ...), because the names may contain characters that must be URL-encoded, particularly blanks. In contrast to browsers, cURL does not do it automatically, but reports an error, if characters that must be URL-encoded are not encoded. However, the numerical part of the channel ID is usually sufficient for identifying channels unambiguously. The pause command at the end pauses batch processing and gives you the opportunity to read what has happened, particularly error messages from cURL, before the window closes. P.S. On 4/16/2025 at 10:45 PM, malle100 said: can see some of the streams stop even after about 15 min and do not start again. I've encountered instabilities when using 239.0.0.1 as multicast IP address. Maybe there is a conflict with some other software (?) ...to be continued later. Quote
Griga Posted April 24, 2025 Posted April 24, 2025 In the meantime I have elaborated the multicast thing a bit more, in order to make it more handy. In the change log it looks like this: Zitat Added: API/RTSP Server: After each successfully processed setup command for UDP/RTP unicast and multicast streams (see here) the web server outputs a list of running RTP streams as plain text by enumerating their setup parameter strings plus the current error state. 0 means no error. Other error numbers originating from WinSock2 can be looked up here. The output is displayed by the browser or a tool like cURL used for sending the setup commands. A web server URL without parameters can be used for getting this information without setup changes. Example: http://127.0.0.1:8089/rtp Added: API/RTSP Server: Additional stop parameter for controlling UDP/RTP unicast and multicast streams via the web server (see here). It provides the following possibilities: stop=all: Stops all currently running UDP/RTP streams. No other parameters are required. Example: http://127.0.0.1:8089/rtp/?stop=all stop=true. Stops the stream with the specified IP address and port, if it is running. Otherwise the command takes no effect. Example: http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&stop=true stop=false: Starts the stream with the specified ip address, port and channel, if it is not running yet. Otherwise the command takes no effect. Example: http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&chid=2359890840093486438|ZDF&stop=false The web server output (first point) is helpful to spot errors and to find out why a stream has stopped unexpectedly. The stop commands (second point) are particularly designed for setting the multicast streams to a defined state. It is not so easy with the "toggle" commands, that start a stream, if it is not running, and stop it, if it is running. The new features require a new version, of course. You can have a pre-release test version, if desired. Another point of interest may be how Windows auto-start mechanisms can be used to launch a batch file, that starts streams automatically e.g. after boot-up. We can discuss it on demand... Quote
malle100 Posted April 26, 2025 Author Posted April 26, 2025 On 4/17/2025 at 8:30 AM, Griga said: It must be done manually. That's why I have proposed to store the setup commands as bookmarks in your browser. However, I think there should be a mechanism that starts multicast streams automatically on Media Server start. For example a list of the multicast setup commands in a text file, that is read by the Media Server on start. Additionally there should be a setup command that stops all multicast streams without having to stop the Media Server. I will try to add something like this as soon as I find time for it. I don't know why this happens. Maybe a network issue? If this happens again, please tell me the time when it happened and attach another support.zip, so I can check in the svcdebug.log if there was something special going on at this time. The Media Server can't update CI modules or CAMs, because there is no API (Application Programming Interface) for it. Maybe it can be triggered manually in the TV/Radio -> CAM menu displayed by DVBViewer. There is no "Do not use" setting that applies to the RTP multicast server (only for the web server and the UPnP server). However, you can use a multicast setup command parameter for specifying the IP address of the network adapter that shall be used for sending multicast, like the violet part in the following example (nic = Network Interface Card): http://127.0.0.1:8089/rtp/?ip=239.0.0.1&port=5018&nic=192.168.54.100&chid=2359890582721931325|Das Erste HD I have changed the IP to 239.100.100.1 and now it works, I have tested for a week, without streams being stopped Quote
malle100 Posted April 26, 2025 Author Posted April 26, 2025 On 4/24/2025 at 12:24 PM, Griga said: In the meantime I have elaborated the multicast thing a bit more, in order to make it more handy. In the change log it looks like this: The web server output (first point) is helpful to spot errors and to find out why a stream has stopped unexpectedly. The stop commands (second point) are particularly designed for setting the multicast streams to a defined state. It is not so easy with the "toggle" commands, that start a stream, if it is not running, and stop it, if it is running. The new features require a new version, of course. You can have a pre-release test version, if desired. Another point of interest may be how Windows auto-start mechanisms can be used to launch a batch file, that starts streams automatically e.g. after boot-up. We can discuss it on demand... Great, I will try. thank you very much for good and fast support. Quote
Griga Posted April 27, 2025 Posted April 27, 2025 Am 26.4.2025 um 08:22 schrieb malle100: Great, I will try. thank you very much for good and fast support. Please check your personal messages. Quote
malle100 Posted May 4, 2025 Author Posted May 4, 2025 On 4/27/2025 at 10:36 AM, Griga said: Please check your personal messages. Hello The new software works really well, nice to be able to see if there is an error in the streams. Is it possible to send out in UDP instead of RTP, have a device that is not happy with RTP? Quote
Griga Posted May 4, 2025 Posted May 4, 2025 vor 2 Stunden schrieb malle100: Is it possible to send out in UDP instead of RTP It is UDP! The layers are UDP (User Datagram Protocol) containing RTP (Real-Time Transport Protocol) containing a TS (Transport Stream) containing PES (Packetized Elementary Streams) containing whatever... like a Matryoshka doll, that's how it is done in Sat>IP. It is possible to omit the RTP layer. However, RTP mitigates some of the UDP disadvantages (see link above). e.g. by providing a packet sequence counter that enables client-side packet reordering if they arrive in wrong order. Pure UDP is more prone to disturbances. That's why RTP is almost always used as additional layer when video/audio is sent as UDP. You can try to change the URLs from rtp://... to udp://... for the device in question. Maybe it will accept them in this way. Quote
malle100 Posted May 11, 2025 Author Posted May 11, 2025 (edited) A future wish would be if you could see which tuner the different streams use. Edited May 11, 2025 by malle100 Quote
malle100 Posted May 19, 2025 Author Posted May 19, 2025 After the most recent update of the DVBViewer server, I am experiencing a problem. can't stop server, it doesn't turn gray anymore and the program freezes, so restarting the computer is necessary. everything else works fine. Quote
Griga Posted May 20, 2025 Posted May 20, 2025 vor 19 Stunden schrieb malle100: I am experiencing a problem. can't stop server, it doesn't turn gray anymore and the program freezes I don't think that the additional multicast control facilities of the 3.3.1.2 test version can cause such an issue, and I wonder what else your Media Server is doing. It would be good if you would attach a support.zip here, so I can check the svcdebug.log. Quote
