chimen Posted May 30, 2005 Posted May 30, 2005 I have tested the twinhan dvb-T card. It kind of works. But somehow it depends on the original Twinhan software. If I have watched a channel at a certain frequency on the original twinhan software (twinhan dtv) then I can use DVBViewer with that frequency. I can scan for channels and watch the channels I find (both free and pay). But only at that frequency. After that I reformated my harddrive and reinstalled windows xp and installed only the drivers for the card, not the twinhan software, and then installed DVBViewer. Now I can't find any channel when I scan. Why is it that I first have to use Twinhan DTV to be able to use the card in DVBViewer?? Great program except for this problem!!! Quote
hackbart Posted May 30, 2005 Posted May 30, 2005 well, could you try this module? http://www.DVBViewer.com/forum/index.php?a...st=0#entry58274 And i expect the problem with is caused by the old sdk. Unluckily the twinhan upgrades are a pain in the ass. If it is not working, drop me a mail and i send you the current sdk. Christian Quote
admi-ral Posted May 30, 2005 Posted May 30, 2005 @chimen: i also tried only installing the drivers. didn't work, had to install from the drivers setup.exe the whole stuff until DVBViewer worked as expected. be sure to have the latest driver/application Quote
chimen Posted June 1, 2005 Author Posted June 1, 2005 Nope, didn't work. Please send me the current SDK. Quote
vic20 Posted June 1, 2005 Posted June 1, 2005 I have exactly the same problem, is there any solution? Quote
Guest Oliver Posted June 1, 2005 Posted June 1, 2005 well, could you try this module? http://www.DVBViewer.com/forum/index.php?a...st=0#entry58274 And i expect the problem with is caused by the old sdk. Unluckily the twinhan upgrades are a pain in the ---------------. If it is not working, drop me a mail and i send you the current sdk. Christian <{POST_SNAPBACK}> Quote
vic20 Posted June 1, 2005 Posted June 1, 2005 (edited) Where do i put the "module"-file? Edited June 1, 2005 by vic20 Quote
vic20 Posted June 2, 2005 Posted June 2, 2005 Any suggestions how to get it working? Looks like this program is the best out there for this card as soon as you can watch all the channels. Quote
mhelin Posted June 3, 2005 Posted June 3, 2005 That module works only with DVB-S cards. Tried it with my C card and in Channel scan got the DVB-S scan parameters. How does DVBV deduct which card it uses if you select a module? There should be a setting for this. Quote
chimen Posted June 4, 2005 Author Posted June 4, 2005 vic20, you are supposed to put the module file in a directory called Modules in the DVBViewer dir. But when I do that I can't start the program. I tried another module earlier, but with that one, I could only see dvb-s stuff in the search dialog. Please help! I love this program. Quote
chimen Posted June 12, 2005 Author Posted June 12, 2005 Come on, isn't there any soulution to this problem? Quote
