linusalba Posted January 13, 2003 Posted January 13, 2003 Hi, when i make a channel scan with 5 MHz of stepsize i find some duplicate channel. What's the best stepsize for you so that i don't find duplicate and don't miss any used transponder? bye, Marco Quote
Guest hackbart Posted January 13, 2003 Posted January 13, 2003 i'll add some "ignore double channels". The problem is the ServiceID, the only problem i have is if the same channel has different ServiceID's i'll add it to the list.. Christian Quote
Flepp Posted January 13, 2003 Posted January 13, 2003 i'll add some "ignore double channels". The problem is the ServiceID, the only problem i have is if the same channel has different ServiceID's i'll add it to the list.. Christian Hi Christian The problem with this frequency based search is that you'll never find out the correct center frequency.Analog receivers do tune correctly because they have AGC. If you have a step size of example 5mhz and bandwith of transponder is 54 Mhz you will find 10 times the same Channels and the frequency will be about 20Mhz below the correct center frequency. Also the SS2 tuner does detect symbolrate automaticaly if you set symbolrate to 0.That means that the predefined sysmbolrates of 27500,22000 are obsolete and could be replaced with 0(autodetect). Is it possibe to read transponderlist from NIT and scan only given transponders ? Cu Flepp Quote
linusalba Posted March 15, 2003 Author Posted March 15, 2003 i'll add some "ignore double channels". The problem is the ServiceID, the only problem i have is if the same channel has different ServiceID's i'll add it to the list.. Hi, what about this features? Do you think you'll develop? Bye bye, Marco Quote
Griga Posted March 15, 2003 Posted March 15, 2003 I've prepared some code for Christian which should kick those duplicates (they are still found, but no longer stored), and I'll send it to him right away... maybe he did something similar by himself in the meantime, then we'll have another duplicate but I'm sure you won't mind this one. Cheers Griga Quote
TomH Posted September 13, 2006 Posted September 13, 2006 I've prepared some code for Christian which should kick those duplicates (they are still found, but no longer stored), and I'll send it to him right away... maybe he did something similar by himself in the meantime, then we'll have another duplicate but I'm sure you won't mind this one. Cheers Griga Hi. I bought DVBViewer Pro few weeks ago and found a problem that I think might be related to this issue. I have FireDTV and when I scan in MyTheatre I get the same channel on 3 different frequencies: 482MHz, 554MHz and 778MHz But DVTViewer only add the first frequency (482HHz) but ignore the other 2 frequencies. The problem is that I need 554MHz because it's a strongest frequency for that channel. What to do? Please help! Quote
Griga Posted September 13, 2006 Posted September 13, 2006 Griga Mar 16 2003, 01:16 AM Hey, you've really digged deep Questions: 1) Why do you use this "blind scan" feature and not a transponderlist? I'd only use it for checking single frequencies that are not included in such a list. 2) What kind of DVB network do you scan? 3) Did you already try TransEdit (see members area, more information here). Quote
TomH Posted September 13, 2006 Posted September 13, 2006 Hey, you've really digged deep Questions: 1) Why do you use this "blind scan" feature and not a transponderlist? I'd only use it for checking single frequencies that are not included in such a list. 2) What kind of DVB network do you scan? 3) Did you already try TransEdit (see members area, more information here). Well I did a search. 1. I use Europe.ini to scan for freq. I guess that is a transponder list ? 2. DVB-T Terrestrial (Sweden) 3. No. Why? Will that help? I'm quite new to this so please have mercy with me… Quote
Griga Posted September 13, 2006 Posted September 13, 2006 1) Yes, it is. Now I'm getting it right. You don't use the "blind scan" feature, to which the previous postings are related - that misleaded me (it's only available for DVB-S anyway). It rather looks like you're receiving the same channels from different DVB-T regions. 3) Yes. TransEdit won't kick double results. However, I suppose DVBViewer Pro will keep them too if you tick "Sort by frequency" instead of "Sort by provider" in the scanner window, because in this case channels with a different frequency go to different category folders. Suggestion to the Pro devs (if one of them happens to drop by): "Sort by frequency" should be ticked by default in case of DVB-T. Saves some trouble... Quote
TomH Posted September 14, 2006 Posted September 14, 2006 (edited) 1) Yes, it is. Now I'm getting it right. You don't use the "blind scan" feature, to which the previous postings are related - that misleaded me (it's only available for DVB-S anyway). It rather looks like you're receiving the same channels from different DVB-T regions. 3) Yes. TransEdit won't kick double results. However, I suppose DVBViewer Pro will keep them too if you tick "Sort by frequency" instead of "Sort by provider" in the scanner window, because in this case channels with a different frequency go to different category folders. Suggestion to the Pro devs (if one of them happens to drop by): "Sort by frequency" should be ticked by default in case of DVB-T. Saves some trouble... Yes, I got it working, yesterday... It's working fine in TransEdit. I'm making my own transponder list and get all channels on the right freq. 1. But I can't save/export the list? Why? 2. And how to import the list to DVBViewer ? 3. I'm also editing the Europe.ini in Notepad and save it. Then restart the DVBViewer. Just putting EUR2 as a debugger... ------------------ [sATTYPE] 1=5000 2=Terrestrial (EUR2) [DVB] 0=5 1=506000,8 2=530000,8 3=554000,8 4=730000,8 5=754000,8 ------------------ Hey, its working! Edited September 14, 2006 by TomH Quote
Griga Posted September 14, 2006 Posted September 14, 2006 1) Because you are using the restricted free/demo version from the public download area. Get TransEdit 3.0 from the members area. 2) DVBViewer and TransEdit share the transponder list files, if you store TransEdit.exe in the DVBViewer folder. For exporting the scan results see http://www.DVBViewer.com/griga/TransEdit%2...ow.html#Context Quote
