PIP sound switching has disappeared. (F5 - OSD Red)
Szines Géza
Greetings!
I don't know if this is a bug or feature!
I just noticed (I don't know how long it's been like this.) that I can't switch between the main show and the secondary show sound while the picture is active. I could do this before with the F5 key (OSD Red), but now it is inactive!
This is what happens: The main show is muted but the secondary sound does not appear!
Version 7.3.1.0
Edited by Szines Géza
vor 10 Minuten schrieb Szines Géza:
You are probably in PiP "Keys Move Mode". That means, number keys are used for controlling the PiP window, including moving and resizing it. In this case you need to press 0 for switching between main window and PiP window audio.
Press F8 (OSD Blue, context menu) and 1 while PiP is active for returning to normal mode, or 0 (Help) for getting more information.
Even using the “0” key does not change the sound. In either mode.
In "Keys Move Mode", the sound will be silenced for a second and then return to the main show sound.
In "Normal Mode", the same thing happens as if I were using F5.
(Or vice versa. Because it's not clear which mode is which!)
I don't think it will be a control (key command) error.
It's just that DVBViewer is not playing your audio!
In the DirectX settings, everything is set to LAV Decoder (Video A-B. Audio A-B.)
Strange. It is no known DVBViewer issue, and I can't reproduce it here. So it may be due to special conditions on your PC or in your DVBViewer installation.
Does it work with right-clicking the PiP window -> Picture in Picture Audio?
Maybe an attached support.zip (after reproducing the issue in DVBViewer debug mode)  will help to narrow the cause of the issue down.
vor einer Stunde schrieb Szines Géza:
If the OSD Blue context menu offers to switch to Keys Move Mode, you are in normal mode, and vice versa.
No change. It works (not) the same with the mouse.
I attach the support.zip!
TV card name: TBS 6281
VGA: AMD 7900XTX
I can also imagine that I might have changed something in the LAV filter.
Can I reset it?
Looks like you haven't configured the playback components on Settings -> Options -> Picture in Picture yet, particularly on the Audio tab. The main window is using "4 - DENON-AVR" as audio renderer, while the Picture in Picture audio renderer is still "Default DirectSound Device", I guess. It refers to the audio output that is configured as default in Windows and is the general default setting in DVBViewer.
Please check if the audio renderer selection for the main windows and/or the PiP window is causing the issue.
None of the settings helped, but for the moment they are not important. I have reinstalled the player and the default settings have no such problem.
If it comes up again, I will contact you.
Thanks for your help!
