drhoegli Posted May 31, 2005 Posted May 31, 2005 Hi, the EPG data is displayed correctly on-screen when switching channels, the Whats Now part of the EPG window also shows correct information, the EPG section and the timeline however is empty for all channels. I'm using DVBViewer 3.1. The DVBViewer 2.2 which is also installed shows correct EPG info. Any hints? Frank Quote
Griga Posted June 1, 2005 Posted June 1, 2005 Try to rescan the affected channels. Data that is used internally to assign the EPG information to specific channels may be missing or wrong. Quote
