Disecq reset ??
giorusso
....as I use my SkyStar2 with signal out from my DreamBox, everytime I use DVBViewer and then I close it up, my disecq remain under my htpc control and I cant see all channels back to my DreamBox...I have to open and close Alt-DVB to have my disecq reset and use my sat receiver normally....so a disecq reset on DVBViewer shut down would be quiet welkome, because I use DVBViewer very much especially 4 HDTV channels.
Tnx. :blush:
Try wether the attached tool does the reset for you.
If yes, DVBViewer GE does it as well, and probably the next DVBViewer Pro version.
LNBOff.zip
