JSON output for MediaServer API
DetlefM
json
I've written a small Python proxy server that adds json functionality to the MediaServer.
I think you should install it on the same computer as the MediaServer (but it also works on a Raspberry Pi in the corner).
Use after installation: Instead of <mediaserver:8089>/api/<apicall>?parameter, call <proxyhost:PORT>/api/<apicall>?json=1&parameter.
If an XML response is recognized, you get it as a json string. Otherwise, you get the normal response from the MediaServer (even if you omit json).
Description and download at https://github.com/detlefm/MediaServerAPI
Feedback welcome.
  • Griga pinned this topic
