Startup takes 5 minutes to load large IPTV playlist
Hello,
I was using a line-up made up of a mix of DVB-T and a few individual IPTV streams, seamlessly.
Load time of DVBViewer was maybe 3-5 seconds, which is OK.
Now, I decided to add a large IPTV playlist, made up of 1.2 million entries (TV channels, movies and series). I have no way to shrink this list, as it is downloaded off a web server on the fly, using credentials passed in the URL. Now, DVBViewer takes 5 minutes to load.
This is OK in case it's done only one time, but the application loads this list every time I launch it... I took a look at the DVBViewer Pro manual and I didn't find a way to use a cached version of the large playlist. What I'd like to do is pick a few TV channels to add to my playlist (I already did that), and then discard the playlist. I would load the playlist manually only once in a while (e.g. once a week) to apply updates done by my IPTV provider. But then, to watch TV, I need to provide my credentials (the credentials are included in the playlist URL)... Is there a way to use this large playlist and have a short loading time?
Thank you 🙏
vor 1 Stunde schrieb calande:
Wow! That's what I'd call a true overkill.
Do you let DVBViewer download and (re-)import the huge playlist automatically on each start by using the -l (lowercase L) commandline parameter, or is the delay solely caused by the 1.2 million entries already being part of the channel list?
Thanks for your reply. I don't use any command line parameter. This is solely caused by the huge number of entries in the channel list. The m3u file weighs 340MB:
Ideally, I'd like to be able not to have to update the playlist several times a day, but instead, update it on demand, when I find out my current playlist is becoming outdated, with deadlinks.
vor 15 Stunden schrieb calande:
No, there isn't. The publisher is to blame. He should split the file in a reasonable way, e.g. into different IPTV categories. IMO offering a 340 MB M3U playlist is idiotic. It would even be hard to find a text editor that is able to handle it.
Anyway, good to know that DVBViewer is able to load such a monster playlist without crashing.
  • Like 1
In addition, the list seems to be loaded from a NAS over network, surely slower than from local drive. Does not make things faster 😉
vor 37 Minuten schrieb HaraldL:
Doesn't matter if the list has already been imported in DVBViewer, so the 1.2 million entries are contained in the channels.dat and ChannelsURL.ini :
vor 22 Stunden schrieb calande:
It could matter on import, but that doesn't affect the DVBViewer start time.
