Better AC3 integration?
Unauthorized
Hi Christian!
I would like DVBViewer to have an advanced AC3 support. Maybe you could add the option for an AC3 pid to the channel list so that DVBViewer could easyly record this stream to. And maybe a button to switch to AC3 stream during watching (it only has to be sent to AC3-Filter, this works already if you enter AC3 pid for Audio pid). Is this possible? Would be much more comfort! :rolleyes:
Guest hackbart
hmm theoretically it is not that act, but i guess it is simpler to add the ac3 pid to the audio pid and declare it as ac3. Since the graph has to build again after the input format is changing, it does not make sense.
Christian
