How to remove exit confirmation?
birko
Hi!
I would like to know how I can remove the confirmation when I want to close with my remote control. In options I put normal and extend exit but in both case the confirmation is displayed.
Thanks
which programm? which version? what kind of confirmation?
Sorry, I have DVBViewer 3.1, the confirmation appears when I press the power buttom of my remote in the screen appears something like "Are you sure? Yes No" So I have yo go to the computer and with the mouse click on yes. I want that when I press POWER, DVBViewer closes in that moment.
Thanks
  • 2 months later...
I find it weird the box appears when using a skin but not when using no skin. I wonder if there is a option to disable this confirmation. The option "Timeout for shutdown warning" set to 0 did not help.
DVBViewer 3.1,
no support for outdated versions !
We dont want to handle errors which are solved!
