visuel Posted June 10, 2005 Posted June 10, 2005 (edited) Since DbvViewer now supports the SkyStar CI card, wouldn't it be nice to have a card sharing module, so that other DVBViewers (connected through the LAN/WAN ) without a smartcard can also look to encrypted channels. Edited June 10, 2005 by visuel Quote
Guest Oliver Posted June 10, 2005 Posted June 10, 2005 The next release will feature an integrated streaming solution for the currently tuned channel. Bye Quote
visuel Posted June 10, 2005 Author Posted June 10, 2005 The next release will feature an integrated streaming solution for the currently tuned channel. Bye <{POST_SNAPBACK}> That is not exactly the same feature. Anyway it sounds as a great new feature! Quote
Derrick Posted June 10, 2005 Posted June 10, 2005 That is not exactly the same feature. ..you´re right. This question is against the rules. Don´t ask again.. Quote
admi-ral Posted June 11, 2005 Posted June 11, 2005 This question is against the rules yeah, but shouldn't these rules be fitted on the legal support of payTV? if it is legal to stream to more than one pc/tv-set with *one* smart-card or not is afair not the problem of DVBViewer But I heard of some people who are with Twinhan DTV CI (+P.....) able to watch the Bundesliga in Garden using the DVBServer Streaming Engine Quote
Guest Oliver Posted June 11, 2005 Posted June 11, 2005 yeah, but shouldn't these rules be fitted on the legal support of payTV? They have been - some weeks ago. Bye Quote
admi-ral Posted June 11, 2005 Posted June 11, 2005 uups, then I forgot to do my daily lectures a couple of days... Quote
