fritzelly Posted September 24, 2025 Posted September 24, 2025 Not sure if this is an issue with DVBViewer or XEPG I get a full epg from Schedules Direct XEPG seems to parse this fine but when I check in DVBViewer some channels only have now and next. I've unpaired and repaired them multiple times, The xml file contains some 10 days of listing It's only about 10 channels Can anyone help? Thanks Quote
Griga Posted September 25, 2025 Posted September 25, 2025 I would post something like this in the Xepg thread, in order to draw @Delphis attention to it. He is the expert concerning EPG import. Or use @Delphi in the post (like I did above), so he gets notified by the forum software that he has been mentioned. Since it is already done now, there is nothing else you have to do... 1 Quote
fritzelly Posted September 26, 2025 Author Posted September 26, 2025 Sorted - in XEPG Options change import to from DVBViewer to DVBViewer Media Server Now have full listings again Quote
