Patrick Remon Posted October 17, 2025 Posted October 17, 2025 How to create a plugin for DVB Programs like DVBViewer. I've read in this forum another topic but it didn't have enough information. I've heard about something called MDAPI but I didn' t find its documentation or any information about it on the internet! I tried to create a plugin in Visual Studio 2012 (Win32 Project) using ModuleAPI posted in this forum but the plugin didn't appear in the plugins tab in the program. Quote
Griga Posted October 17, 2025 Posted October 17, 2025 You can find some plugin programming basics in the SDK that can be downloaded here. Further help will be provided on demand, if possible. MDAPI is not supported natively. Maybe there are bridge plugins for translating it to the DVBViewer API, but I've never used something like that. Quote
Patrick Remon Posted October 17, 2025 Author Posted October 17, 2025 2 hours ago, Griga said: You can find some plugin programming basics in the SDK that can be downloaded here. Further help will be provided on demand, if possible. MDAPI is not supported natively. Maybe there are bridge plugins for translating it to the DVBViewer API, but I've never used something like that. But most plugins work on all DVB Programs, how? Is it the same SDK or the code of the plugin is programmed in every SDK? Quote
Griga Posted October 18, 2025 Posted October 18, 2025 vor 15 Stunden schrieb Patrick Remon: But most plugins work on all DVB Programs, how? I don't know. I have no experience with that. Many years ago I developed some plugins, but only for DVBViewer. AFAIK the DVBViewer plugin API is a proprietary thing, which means, plugins that are using it will only work with DVBViewer. Quote
t5b6_de Posted December 10, 2025 Posted December 10, 2025 It's an old thread i know, but let me answer this question. i wrote a plugin about 6-8 years ago for DVBViewer many other. The key is, to implement all interfaces of all applications in parallel, which goes onto your core plugin functionality. Every App uses different entry points in the library so its easy to implement the different functions in a single library. difficult is, when different apps using same entry function names with different parameters, then you'll have to implement multiple libraries which are loading your core library plugin and adapt the functions. Quote
