jqpabc123 Posted October 20, 2025 Posted October 20, 2025 Replaced old WinTV DualHD ATSC tuner with a new one of the same model. The old one was having reception issues. The new one is recognized as QAM but not ATSC. How do I fix this? Quote
jqpabc123 Posted October 21, 2025 Author Posted October 21, 2025 >>> Where? In DVBViewer? Yes. I am using DVBViewer Pro to watch local digital broadcasts in the USA (ATSC). Quote
Griga Posted October 22, 2025 Posted October 22, 2025 And you can't change the tuner type from cable to ATSC on Settings -> Options -> Hardware? Try the following: Select Help -> Configuration Folder in DVBViewer (opens an Explorer window). Close DVBViewer. Open the file hardware.xml with a text editor (Notepad). Look for <entry name="TunerType">0</entry> and replace 0 by 3 Save and restart DVBViewer. Does it work? Please also attach your hardware.xml as file here, so I can fix it in future DVBViewer versions. Quote
