DVBViewer problem
mike28
After installing skystar2 PCI,i got this error after playing DVBViewer..
EAccessViolation raised by instance tmrTune of class TTimer at 1CF402F8C :in
Modul "netaudio.ax'/ address 0000004
I cant view anything on screen
Plz help..
Thx in advance
Guest Oliver
Unregister netaudio.ax. Doesn't belong to the DVBViewer.
Bye
Bye
Thx for reply ..
Iam new user..
how to unregister netaudio.ax?
thx again
Bye
Thx for reply ..
Iam new user..
thx again
First of all search for the folder where the file netaudio.ax is located...
Go to Start -> Run -> type cmd -then press Enter) navigate to the folder where netaudio.ax is located (for example: cd c:\program files\someprogram\ )
then type:
regsvr32 /u netaudio.ax
and press enter. :(
This will unregister the problematic file..... ;)
I tried to find this file netaudio.ax but there is no such file in my PC?
Its strange..i searched many times..
Y i'm getting this error.
regards
Bye
Thx for reply ..
Iam new user..
thx again
then type:
and press enter. :(
regards
Did you also take a look to the ususally hidden directories?
Try to locate netaudio.ax in C:\WINDOWS\system32
If you cant find that file at all this might be due to deleting that file without properly unregistering it before ...
