dirk4000 Posted June 21, 2005 Posted June 21, 2005 I do not know why this program has no search function for tv shows in the epg guide window of your program. It is a feature that is easy to implement and adds a real value that should not to be underestimated. Kind regards, Dirk Quote
Guest Lars_MQ Posted June 22, 2005 Posted June 22, 2005 Have you ever looked into the manual. The filter button opens a menu, which offers some options for limiting the displayed selection, either to today's broadcasts or to broadcasts starting from the actual time (in the station-specific mode), or to radio or television stations (in the time-specific mode). Here you can also access the search function (see picture above “find in EPG”). With the search function you cannot only find certain broadcasts, the rerun dates are also shown. You can access the search function with a double-click onto the header of the "event"-column. Quote
IRa Posted June 22, 2005 Posted June 22, 2005 Filter works fine but what I have been missing is filter using program classification information which is avalible. Would that be possible? Quote
