Paul Dick Posted December 19, 2025 Posted December 19, 2025 Is it possible to control the TV tuner to which DVBViewer is connected (switching LCN channels, receiving information about the presence of a stream, etc.) programmatically via WM messages? Quote
Griga Posted December 21, 2025 Posted December 21, 2025 Assuming WM Messages means Windows Messages that can be sent with SendMessage or PostMessage to DVBViewer: Yes, there are such messages that can be used to control DVBViewer and let it perform certain actions. But maybe not to the exent that you want/need. Specifically, there are no messages that deal with LCN. It would be easier to answer your question if you would explain in more detail what you want to do / acheive. Quote
Paul Dick Posted December 21, 2025 Author Posted December 21, 2025 The Behold TV tuner has a way to control the tuner and receive data from it via WM messages (Windows Message). That is, the user can send commands (messages) to the tuner and receive data about their parameters from it in response. For example, We are sending a request to the tuner about which channel the tuner is currently working on. He sends us the channel number in response. We send a message to the tuner - a command to switch to channel No. 2. He switches to channel 2. We send a request message to the tuner asking if there is a carrier frequency at the input of the tuner (sync pulses in the video signal). In response, it sends the value 0 or 1 (True or False). Here are examples of how this is done in the language VisualBasic.Net. Imports System.Runtime.InteropServices 'For receiving messages via WM_ '====To work with the Behold TV tuner ================================= <DllImport("user32.dll", CharSet:=CharSet.Auto)> _ Public Shared Function FindWindow(<MarshalAs(UnmanagedType.LPTStr)> ByVal lpClassName As String, <MarshalAs(UnmanagedType.LPTStr)> ByVal lpWindowName As String) As IntPtr End Function <DllImport("user32.dll", CharSet:=CharSet.Auto)> _ Public Shared Function SendMessageA(ByVal hBhWnd As IntPtr, ByVal wMsg As Integer, ByVal wParam As Integer, ByVal lParam As UInteger) As Integer End Function <DllImport("User32.dll")> _ Public Shared Function PostMessage(ByVal hBhWnd As IntPtr, ByVal msg As Int32, ByVal wParam As Int32, ByVal lParam As Int32) As Integer End Function Const WIN_CLASS As String = "TMain" Const APP_NAME As String = "BeholdTV" 'or "BeholdTV.Inst2" 'While writing the main Instance Behold, because APP_NAME cannot be changed, it is a constant. Private hBhWnd As IntPtr = FindWindow(WIN_CLASS, APP_NAME) 'Then when uploading the form here, instead of APP_NAME, we will enter the Instance from the list. Const WM_USER As Integer = &H400 Const WM_BHCMD As Integer = WM_USER + 200 '====To work with the Behold TV tuner ================================= hBhWnd = FindWindow(WIN_CLASS, "BeholdTV") 'We are defining an instance of the Behold TV tuner. '==== Examples of WM messages to the Behold TV tuner ==================================== Dim WMBH_GETCHNLN As Integer = WM_USER + 287 'Get the channel number Dim ChnlNB As Integer = SendMessageA(hBhWnd, WM_BHCMD, WMBH_GETCHNLN, 0) 'Get the channel number Dim WMBH_CHNLN As Integer = WM_USER + 201 'Switch to channel with absolute sequence number 1....999 Dim CHNLN As Integer = SendMessageA(hBhWnd, WM_BHCMD, WMBH_CHNLN, Channal_N) 'Switch to channel no. Channal_N. Dim WMBH_CHNLUP2 As Integer = WM_USER + 203 'Switch to the next channel Dim NextChnnl2 As Integer = SendMessageA(hBhWnd, WM_BHCMD, WMBH_CHNLUP2, 0) 'Switch to the next channel Dim WMBH_GETPLOCK As Integer = WM_USER + 286 'Get the status of a video signal Dim Fn As Integer = SendMessageA(hBhWnd, WM_BHCMD, WMBH_GETPLOCK, 0) '==== Examples of WM messages to the Behold TV tuner ==================================== My question. If it is possible to control TV tuners via DVBViewer through such messages, please provide examples of how to do the following. 1. Set the TV tuner to the frequency of 618 MHz digital DVB-T2 broadcasting. 2. Switch the TV tuner to LCN channel 2 of the first multiplex of terrestrial television broadcasting. 3. Switch the TV tuner to the next channel. 4. Display the image of the TV channel on the DVBViewer screen itself. 5. Display the image of the TV channel on the Control "Panel1" of the project form. 6. Get information from the tuner or DVBViewer about the presence of the carrier frequency of the current TV channel at the input of the tuner. 7. Get information from the tuner or DVBViewer about the availability of the current TV channel stream. 8. Get information from the tuner or DVBViewer about the availability of an image of the current TV channel. 9. Get information from the tuner or DVBViewer about the sound availability of the current TV channel. It would be very nice if these examples were given in the language VisualBasic.Net . If you give examples in the language VisualBasic.Net there is no way, they can be given in the Delphi language. Thank you very much in advance! Quote
Paul Dick Posted January 17 Author Posted January 17 Can anybody answer my question above (December 21, 2025)? Quote
Griga Posted January 18 Posted January 18 Am 21.12.2025 um 13:11 schrieb Paul Dick: If it is possible to control TV tuners via DVBViewer through such messages, please provide examples of how to do the following. Sorry, missed that. Regarding your catalogue above: There are no messages that are related to a specific hardware. Only to the DVBViewer UI. Tuning can be performed by channel list index or channel ID, not by LCN or frequency. DVBViewer will allocate a matching hardware for playing the channel, but won't tell you which hardware is used (however, if there is only one tuner for a given reception type, you will know, of course). You can query which channel is currently played, but no availability information can be retrieved by messages. But by using a plugin (DLL) that exports certain functions you can get a tuner dataset containing reception parameters, IDs, PIDs etc when DVBViewer tunes a channel., request streams (PIDs) or the whole mux by using messages, receive the TS via callbacks and look it up yourself. Another possibility is using the DVBViewer COM interface and VBScript or a similar language. There are examples in the Scripts sub-directory of the DVBViewer program directory. Sorry, I don't have much time for it now. And explaining everything that is not possible or possible and giving examples for it will take a lot of time Anyway, I will check if there is some documentation available and post it here as soon as I find time for it. Quote
