Shaun White Posted December 19, 2025 Posted December 19, 2025 I've been using the Media Server and DVBViewer for ages now and I'm increasingly finding this problem. I have it make auto timers and rely on it to wake my sleeping PC, record the show, then put it back to sleep. It's mostly unmonitored. What I find is, I usually notice that first thing in the morning, the PC is awake when it shouldn't be. I turn on my screen, hover over the server icon in the taskbar and it tells me the the next timer to start is actually the one from the night before. My PC has woken up, but the recording hasn't happened. If I open the web interface, that appears stuck too and still shows the timer event that didn't happen. I either restart the server or my PC and then it will update to show the next timer. I took a look at the logs and I can see entries like "Invalid Timer" with the program that should have recorded the previous night. Before I do a fresh install of Windows, please can someone knowledgable take a look and tell me if there's something in my setup that's wrong? It's a relatively new PC I built in Jan 24 with a Hauppauge HVR5525 which gets an aerial and satellite feed and then a USB Nova S2 Satellite stick. Thanks for any help anyone can give. I'm leaving the PC on from now on to see if my timers start without it having to come out of sleep. support.zip Quote
Griga Posted December 20, 2025 Posted December 20, 2025 vor 15 Stunden schrieb Shaun White: My PC has woken up, but the recording hasn't happened. I can see it in the svcdebug.log. Though the Media Server is running, there is not even an attempt to start the recording. Let's have a look at some events that happened lately: 17.12.25 18:43:14: The Media Server gets Windows a message that your PC is about to enter energy saving (sleep/standby) mode, so it sets up a wake time for the next recording at 18/12/2025 21:47:00 18.12.25 22:00:10: The PC wakes up, 13 minutes too late. Why? I can see no reason for it. Or does your PC need such a long time for getting up? (Some people do, but that's another thing). However, the Media Server still should start the recording, except if its duration is 13 minutes or less. But nothing happens at all. No more log entries until 19.12.25 03:15:11: There are three attempts to connect to the Web Server of your Media Server via the internet, two from China, one from the USA (I've entered the IP addresses in a "whois" service for finding out). The Media Server blocks these requests, because (luckily) it is configured for not allowing access from other networks but your home network. The blocking proves that your Media Server is still responsive. Nevertheless this is a bit weird, because usually the firewall in your router should already block such requests, but it doesn't, which means it it is configured to forward requests to port 8089 from outside to your Media Server. Did you induce that? Many connection attempts like that can be found in your log. The whole world seems to be interested in your Media Server. 19.12.25 06:30:39: The Media Server is stopped (manually by you, I guess). 19.12.25 06:31:20: The Media Server gets re-started, loads its timer list and finds a timer for a programme that is already completely in the past, which triggers the "Invalid timer" entry in the svcdebug.log. The missed recording is Inside No. 9: The Devil of... - ...Christmas. 1/6. Austria, Krampusnacht 1977. Who, 18/12/2025 22:45:00 Why does the Media Server set up a wake time at 18/12/2025 21:47:00 for it (almost 1 hour too early)? Why does the PC wake up too late (18.12.25 22:00:10)? However, this was still early enough for recording the programme, but why is the timer completely ignored by the Media Server? Unfortunately the log doesn't answer these questions. There are no errors whatsoever. The only possible reason I can think of for not executing a timer without any comment in the log is the timer being disabled. Quote
Shaun White Posted December 20, 2025 Author Posted December 20, 2025 Thanks Griga, I really appreciate you taking a look for me. I noticed the odd wake times too. I always have my timers set to 10 minutes before the recording starts and to last 15 minutes after and the times I saw in the log looked right off. If a program's due to start at 21:00, I'd expect the PC to wake up around 20:49 but that's not happening is it. The external access attempts are my fault because yes, I have set up port-forwarding rules in my router. I wanted to be able to use the DVBViewer app on my phone to remotely add timers. To be fair, I hardly ever do that so I've removed the rules. Yes, It'll be me stopping the server and then restarting it again as it just gets "stuck" I checked the BBC website for that episode of Inside No. 9 and it helpfully tells me that this was last on at 22:00 on the 18th so taking my 10 minutes off this would make the Server's wake up time of 21:47 right but then why does the missed recording entry have a time of 22:45? Very odd. It's not something to do with GMT or British Summer time is it? I left the PC on for a recording last night and that worked. If it wasn't Christmas in a few days with lots of stuff on TV to record, I'd do a fresh install of Windows. I wasn't technical enough to see if there was something fixable but if it's a mystery, I think once all the Christmas TV is done, it'll be a reinstall and start again. Quote
HaraldL Posted December 20, 2025 Posted December 20, 2025 As it's not an older PC I assume the CMOS battery (usually a CR2032) is not at too low voltage, which could cause the mainboard clock, needed for wake up, to run slower or even stop while off or in standby (many don't notice this because as soon as the PC is started the system time is synced from internet and shows the current time then). Perhaps some energy saving features of the mainboard (BIOS) or Windows/Drivers could prevent the proper wake up? As my Win11 is in german perhaps the names are not translated exactly: Classic control panel (enter "control.." in start menu) -> System -> Energy plan -> Change energy plan -> Advanced settings -> Save energy -> Allow wake timers -> Must be Enabled! But I assume this is enabled as otherwise your PC won't wake up at all. Quote
Griga Posted December 20, 2025 Posted December 20, 2025 vor 11 Stunden schrieb Griga: The only possible reason I can think of for not executing a timer without any comment in the log is the timer being disabled. This is the best explanation I have ATM. Your timers were disabled for some reason. Automatically created timers ("auto-timers") as result of an EPG search may be disabled due to the options at the lower right on the Search EPG page. If your timers are "auto-timers", select the search preset that triggered the creation an check these options. On the Timers Page the enabled/disabled state of a timer is indicated by the round buttons at the left (green = enabled, grey = disabled) and can be changed by clicking them. Quote
Shaun White Posted December 22, 2025 Author Posted December 22, 2025 It certainly is a mystery. I cracked the PC open, prised the CMOS battery out and tested it and it isn't that. I left it on Saturday and set some timers which should force the PC to wake and sleep. There were gaps in the timers so no overlap or reason for it to stay awake for the next timer. It successfully did four BBC News programs, sleeping and waking in between according to the event viewer. I set it to record a film last night and nope. It's not playing. It should have woken at 20:50 and it didn't. I manually turned on the machine and once again had to stop and restart the server and then the recording began. I checked my timers and they're all green. On the Search EPG screen, I only have ticks in these boxes and the presets are the same: The film I tried to record last night was a one-off so I have no preset and I picked it from the EPG. I'm doing a Windows reinstall to see if that gives it the kick it needs. Quote
HaraldL Posted December 22, 2025 Posted December 22, 2025 vor 6 Stunden schrieb Shaun White: there were gaps in the timers so no overlap or reason for it to stay awake for the next timer. In the case when there are not enough tuners for overlapping recordings every conflicting entry in timer list would always show in red as an indication. You would see it early if this is the problem. And if the "Create timers deactivated" section would be the cause then 1. the dot in front of the timer would be grey instead of green and 2. if grey the timer would not start recording after stopping/restarting the service as the timer stays deactivated. So this also should not be the cause. Quote
Shaun White Posted December 30, 2025 Author Posted December 30, 2025 Hi, I'm back with an update of sorts. HaraldL, I only mentioned the gaps between the timers as I wanted to force the PC to go to sleep after recording to see if it woke up for the next one. If the timers were too close together, the PC would have just stayed awake. There weren't any conflicting timers or lack of tuners so I don't think that was an issue. As far as I can remember, no timers were grey. They were all green. Anyway, the update is, I've reinstalled Windows and started from scratch. I'm taking small steps too to check things work. So far, I've either picked programmes from the EPG to record or searched for them through the web interface. Normally, I have the Final Action set to Sleep Mode but I've left this off for the moment. I've not created any automatic timers yet. My PC does seem to be waking up at the right time to start recording at the right time. I'll keep monitoring it and turn the Final Action back to Sleep Mode and try auto timers see if the issue comes back. Thanks again Quote
Shaun White Posted December 30, 2025 Author Posted December 30, 2025 (edited) And it's failed again A timer was due to start at 20:50. I forgot until 21:20 and saw the PC turned on so I turned the monitor on to check. The Media Server hasn't started recording again. It still thinks the next timer is for the one it's not started: The recording list is all green for the two timers that haven't started: I even tried changing the system time to see if that would give the server a jolt to start recording and it did nothing. I've added the log entries from yesterday up to now. The actual log was too big to upload Log copy.txt Edited December 30, 2025 by Shaun White adding log Quote
Alan_SP Posted January 2 Posted January 2 (edited) I have something similar, and I just wanted to add my experience. I just updated to the latest version, it might fix my issue, but let's see. I was using 7.2.5.0/3.2.5.0, and now I'm on latest (not beta) version. My PC works all the time, but for some reason, media server crashes silently. Icon is blue, like everything is working as it should. But web interface stops working, and timers don't record. Just stopping and starting media server fixes it for some time (few days). I notice it when trying to access web interface, or I notice missed timers, whatever happens first. I hope it's something caught and fixed in latest version. Edited January 2 by Alan_SP Quote
Shaun White Posted January 2 Author Posted January 2 8 hours ago, Alan_SP said: I have something similar, and I just wanted to add my experience. I just updated to the latest version, it might fix my issue, but let's see. I was using 7.2.5.0/3.2.5.0, and now I'm on latest (not beta) version. My PC works all the time, but for some reason, media server crashes silently. Icon is blue, like everything is working as it should. But web interface stops working, and timers don't record. Just stopping and starting media server fixes it for some time (few days). I notice it when trying to access web interface, or I notice missed timers, whatever happens first. I hope it's something caught and fixed in latest version. That sounds the same as mine doesn't it. Mine works for a few days and then it stops. I'd not thought to call it a crash as the web interface still works but it must have crashed in some way as it's "stuck in time" isn't it. Were your timers working ok with the previous version of media server? I dug an old Windows 10 PC out and was in the middle of setting that up to see if it exhibited the same issues but I'm wondering now whether to try a previous version of Media Server on my current PC. I was really hoping it wasn't an issue with my current PC as I specifically built it to be a sort of HTPC and would be gutted if it were the cause of the problems. Maybe now it isn't if others are finding the same issues. Quote
Griga Posted January 2 Posted January 2 vor 9 Stunden schrieb Alan_SP: My PC works all the time, but for some reason, media server crashes silently. Icon is blue, like everything is working as it should. But web interface stops working, and timers don't record. This may be caused by a damaged media database. If yes, it is visible in a support.zip (in the contained svcdebug.log) and can be fixed easily. Quote
Alan_SP Posted January 3 Posted January 3 (edited) On 1/2/2026 at 12:07 PM, Griga said: This may be caused by a damaged media database. If yes, it is visible in a support.zip (in the contained svcdebug.log) and can be fixed easily. I plan to wait for it to happen again before posting support.zip, it seems that update I made cleared svcdebug.log. When I checked it, oldest time stamp was fresh, after update. But, if you think that even the new support.zip would be useful, I can make and upload it. How can I fix media DB, if it's the cause for my issue? I do think I have just copied settings dir from old to the new PC, which might be why there's damage with DB. Edited January 4 by Alan_SP Quote
Alan_SP Posted January 3 Posted January 3 On 1/2/2026 at 11:50 AM, Shaun White said: That sounds the same as mine doesn't it It seemed very similar, but with few differences. From what I can tell, it might be something with your PC. For example, I had old PC where it worked for months without any issues, it was extremely reliable, and only power loss was causing issues (I didn't setup BIOS to boot it after power returns). On my new PC, I had issues from the start, but it might be caused by some DB issues, or something. I mostly just copied data from old PC, if I remember correctly what I did when I was installing this PC. So, this copying settings might have caused this DB issues. Quote
Griga Posted January 4 Posted January 4 Am 30.12.2025 um 22:35 schrieb Shaun White: And it's failed again A timer was due to start at 20:50. I'm still wondering why the log doesn't even show an attempt to start the recording. The timer is simply ignored. I've never seen something like that before. Another strange thing: The wake up time was set to "Setting next recording: 30/12/2025 20:47:00". However, the first sign of being awake is "20:49:43.859 Timer fired". This means, your PC almost needed 3 minutes to wake up from sleep mode. This is quite long... does it always take so much time? Quote
Griga Posted January 4 Posted January 4 Am 30.12.2025 um 22:35 schrieb Shaun White: I've added the log entries from yesterday up to now. The actual log was too big to upload You may want to delete old attachments here. Anyway, I think I've found something by comparing a working case (recording at 29.12.25 20:50:00) and the non-working case (recording 30.12.25 20:50:00) in the log, where something took way too long when Windows announced that sleep mode will be entered by sending a PBT_APMSUSPEND message. See here: Zitat The system allows approximately two seconds for an application to handle this notification. If an application is still performing operations after its time allotment has expired, the system may interrupt the application. Thats's what happened, causing things that must be executed in the Media Server before entering sleep mode to be executed after the PC woke up, so things got muddled up. I will continue my analysis later... Quote
Shaun White Posted January 4 Author Posted January 4 3 hours ago, Griga said: This is quite long... does it always take so much time? Do you mean like me pressing the power button to wake the PC up? No. No delays at all. I usually wake the PC by pressing a key on the keyboard (wireless/USB) but both that and the power button on the PC wake it up straight away. I sometimes us WOL too as I use Splashtop to access the PC from other PCs or my phone and that doesn't take long either. Thanks for the advice about deleting old attachments. I didn't know about the limit. I tried to compare a working case to a non-working case but it was beyond me so your help is really appreciated. The irritating thing is (beside from me building this PC from scratch) is I reinstalled Windows 11 and the issue was still there. It must be something with this PC. Thanks for continuing to investigate. I've temporarily moved back to my Windows 10 PC for the time being but I'd hate for this newer PC to be sat there doing nothing. Quote
Griga Posted January 5 Posted January 5 vor 21 Stunden schrieb Shaun White: Do you mean like me pressing the power button to wake the PC up? No. No delays at all. Yes. There is a (still unexplained) discrepancy of almost 3 minutes between the intended wake up time set by the Media Server and the actual wake-up time. Anyway, I can now reproduce the timer execution issue by inserting a delay in the Media Server code executed after receiving the "sleep mode" PBT_APMSUSPEND message. However, a 3 seconds delay was not enough. Obviously my Windows 10 does not handle the time allotment as strictly as announced by Microsoft (see above) - may be different under Windows 11. But with a 10 seconds delay I get the same muddled execution sequence as reported in your log, and timers are not executed anymore. The main reason is an internal "Sleeping" flag in the Media Server. It is set after all things supposed to be done after PBT_APMSUSPEND are done, and reset after waking up (after having received a PBT_APMRESUMEAUTOMATIC or PBT_APMRESUMESUSPEND message). But in your case the last part of the sleep mode preparations is executed delayed after the "PC woken up" messages have been processed, causing the "Sleeping" flag to be set after it has been reset. This set flag prevents the periodical execution of a procedure that lets the recorder check if a timer is due to start. There we are... The (unwanted) delay happens in your PC for unknown reasons when the RTSP server is stopped/disconnected on PBT_APMSUSPEND, because the log does not report completion until PBT_APMRESUMEAUTOMATIC/PBT_APMRESUMESUSPEND have been processed. There a two questions arising from that: Why does this delay happen in your PC? Can it be avoided in some way? Difficult to tell, because it does not happen in the Media Server code, but in a network library used by the Media Server. Are there measures that can be taken so the the Media Server continues to work properly even if such long delays after receiving PBT_APMSUSPEND occur? If yes, which side effects and risks have to be considered? Requires further investigation... Quote
Griga Posted January 5 Posted January 5 vor 1 Stunde schrieb Griga: The (unwanted) delay happens in your PC for unknown reasons when the RTSP server is stopped/disconnected on PBT_APMSUSPEND, Another interesting finding: In the working case the RTSP Server was stopped within a millisecond. There were no preceding connection attempts. In the non-working case it obviously took much longer, and there were preceding connection attemps (at 30.12.25 14:41:15), requesting no video/audio from the RTSP Server, but a description.xml containing information about the server capabilities. Some client(s) just checked what's on offer. Similarly entering sleep mode on 29.12.25 23:48:41 did not work properly after client connections to the RTSP server at 29.12.25 23:25:53. This means, the timer issue may depend on the RTSP server being used between the last server start and entering sleep mode. But by which client? Do you know which one it was? Quote
Shaun White Posted January 6 Author Posted January 6 On 1/5/2026 at 10:52 AM, Griga said: This means, the timer issue may depend on the RTSP server being used between the last server start and entering sleep mode. But by which client? Do you know which one it was? I can see two ClientConnect entires at that time but I can't work out what 03B61020 or 03B8A310 might be. I thought they might be part of the MAC address from other devices on the network but I can't see anything that matches. I don't know enough about what these "codes" are to match them up to a device to guess what the client might have been. Quote
Griga Posted January 6 Posted January 6 vor 4 Stunden schrieb Shaun White: I can see two ClientConnect entires at that time but I can't work out what 03B61020 or 03B8A310 might be. That are simply the hexadecimal memory addresses of data structures representing the connection. The values enable to distinguish different connections, nothing more. The RTSP/Sat>IP server within the Media Server announces his presence in your home network by sending a UPnP multicast message to all potential clients that may be interested. They may respond by connecting to the RTSP server and requesting the description.xml for checking what's on offer. Potential clients are all devices / software in your home network that are dealing with UPnP and media playback / media handling, mobile devices like smart phones, TV sets, other PCs etc... so you don't have to find out what is related to the hexadecimal memory addresses, but to remember, which devices / potential clients connected to your home network were active / running at that time. Anyway, in the meantime I have applied some changes in the Media Server that will probably solve your timer problem. You can have a test version if you want. However, you need to install the latest Media Server Beta version as suitable environment for the current development state. After that, I can provide a new DVBVservice.exe via personal forum message as replacement for the current 3.3.1.12 Beta. Nevertheless there are strange things happening in your PC that will not be addressed by this, particularly Am 20.12.2025 um 07:47 schrieb Griga: 19.12.25 03:15:11: There are three attempts to connect to the Web Server of your Media Server via the internet, two from China, one from the USA (I've entered the IP addresses in a "whois" service for finding out). This would make me a bit nervous If your Media Server is accessible from the internet (it shouldn't behind a router), it can be easily found by special search engines, and hackers all over the world might be interested in penetrating... Quote
Shaun White Posted January 11 Author Posted January 11 On 1/6/2026 at 5:36 PM, Griga said: Anyway, in the meantime I have applied some changes in the Media Server that will probably solve your timer problem. You can have a test version if you want. However, you need to install the latest Media Server Beta version as suitable environment for the current development state. After that, I can provide a new DVBVservice.exe via personal forum message as replacement for the current 3.3.1.12 Beta. Nevertheless there are strange things happening in your PC that will not be addressed by this, particularly This would make me a bit nervous If your Media Server is accessible from the internet (it shouldn't behind a router), it can be easily found by special search engines, and hackers all over the world might be interested in penetrating... Hi, thanks for your work on this and sorry for the delay in replying. Because I can't trust this new PC, I've moved back to my Windows 10 machine so I I'd cannibalised the new PC of its parts. Although I don't want that to be a long term solution, the older PC does seem to be working perfectly. However, I don't want your work to go to waste and I don't want my newer PC to go to waste either so I've found an older satellite PCIE card and got the newer PC running again and have installed Media Server 3.3.1.12 on it and set up a few timers. If you can provide a new DVBService.exe, I'd happily test it. My Media Server would have been accessible from the internet but that shouldn't be happening anymore since my first log upload. I've removed the port forwarding rules from my router and I can't see any similar entries in my latest logs. Quote
Griga Posted January 12 Posted January 12 You have a PM. The forum software should notify you about it. The simulation of a long delay in the Media Servers sleep/hibernate mode preparations causing the issues reported by you revealed a disaster. Several parts of the Media Server remained in an inoperable state after waking up from sleep mode: Timers, UPnP, RTSP Server, Media Stream Server (responsible for media file delivery)... only the Web Server and Live Stream Server were still usable. What I did in the test version: Changed the close down process after receiving a Windows PBT_APMSUSPEND for some Media Server parts (RTSP server, Media Stream server). Previously they were shut down completely, while the Web Server and Live Stream Server, which "survived" the disaster, only disconnected all clients, but remained available. Now the Media Server handles the RTSP and Media Stream Server in the same way. Maybe this also shortens the preparation time, so the Windows limit is no more exceeded (to be verified). However, this may also cause unknown side effects. Changed the "Sleeping Flag" handling, assuring that it is set before falling asleep and reset after waking up, so necessary reactivations are executed (UPnP, timer handling). I hope this generally makes the Media Server more robust, even if the Windows time allotment still expires before all sleep/hibernate preparations are done. Please try... Quote
Shaun White Posted January 14 Author Posted January 14 Hi Griga, I did as you said and last night, the PC woke up on time and started recording on time so - so far so good. That was just one timer though. I will add some more timers over the next few days and report back on how it's gone and add the latest log for you to take a look at if that's ok. Quote
Shaun White Posted January 22 Author Posted January 22 I'm back. I've done a week's worth of testing and the news is mostly positive. I tried to pick programs to add to my timers that ran for an hour. With my 10 minutes lead time and 15 minutes post record time, I could easily spot that the majority of my recordings are coming out at around 1 hour and 25 minutes, proving that things were working. Which they mostly are. There have been a few occasions though where the PC is still not waking at the right time and this has been a few minutes late BUT the good news is that with the test version, the server is now reacting straight away and begins recording the program even though the PC hasn't woken up in time. Luckily the PC has woken up before the program has started on these occasions but I still don't trust it 100%. I tried to see if I could change any settings on my PC but all I found from Google was to try setting some USB devices in Device Manager to not allow the computer to turn off devices to save power and also turning off fast start up but I can't say that they've done anything. I wish I knew what was going wrong within the PC to prevent it waking exactly when it should. I've attached my log. Any further thoughts or ideas would be appreciated but thanks again for your help. svcdebug.log Quote
Griga Posted January 23 Posted January 23 vor 12 Stunden schrieb Shaun White: There have been a few occasions though where the PC is still not waking at the right time Maybe related to this: Am 4.1.2026 um 08:40 schrieb Griga: Another strange thing: The wake up time was set to "Setting next recording: 30/12/2025 20:47:00". However, the first sign of being awake is "20:49:43.859 Timer fired". This means, your PC almost needed 3 minutes to wake up from sleep mode. This is quite long... does it always take so much time? A possible reason is the BIOS clock not working correctly. Looks like it's too slow. Quote
Shaun White Posted 3 hours ago Author Posted 3 hours ago Hi, I'm back. I've been doing some further testing to see how things go. I changed the battery on the motherboard to see if that made any difference but I can't say that it has. I found something online that suggested returning the BIOS to a previous "stable" version which I tried but I can't see that it made any difference either. I think you're right though, the BIOS clock can't be keeping time. At worst, it's about 5 minutes slow. Most of my test timers have recorded on time and it's the odd one that wakes late. My first tests involved just recording random programmes throughout the day and now I've changed to a more realistic test to just record the programmes I want. I'm getting the feeling that the longer the PC is asleep, the more likely the next PC wake will be late. I've added some recurring timers throughout the day to update the EPG and the recording database in the hope that these frequent wakes will help the PC keep time better when asleep. One question I did want to ask though, because you provided me with a test version, will the changes in that version go into the standard version or do I stick with the test version even if there are updates in future? Many thanks Quote
