//*PRE|)@T()R*\\ Posted June 22, 2005 Posted June 22, 2005 (edited) hi all i have problem I am use Sky Star 2 /PCI and i'am download DVBViewer program and instal . Join FlySat Site give http://www.flysat.com/nss6.php |exempelare CGN TV 11543 V MPEG-2 39999 7/8 CGN TV -w- 512 640 Kor | configure on SETUP4PC and have signal quality 77% . There please show this Screenshot go to open DVBViewer and have this problem Error on the Screenshot and 2nd use another program MajorDvb And again error : MPEG2 problem . what the problem ???????????????????????? Over sory for my english . Edited June 22, 2005 by //*PRE|)@T()R*\\ Quote
mittern8 Posted June 22, 2005 Posted June 22, 2005 You should try a clean installation without any plugins such as csa.amd.dll first to make sure that the DVBViewer runs properly and because you won't get any support using such (at least for Germany illegal plugins). Furthermore we'd need more detailed info on the Version of DVBViewer you are using. Then read this thread carefully and download the attached tool LogMPEGEncoder so you can give info on the decoders you're using. Next, setup.ini (or, dependant on the version of DVBViewer you're using setup.xml) and DVBViewer.log for a closer examination ... Quote
//*PRE|)@T()R*\\ Posted June 23, 2005 Author Posted June 23, 2005 I am fix this problem BC2C2 MPEG2 . For Sky Star 2 users . Need to configure channel MHz on SETUP4PC etc, go to Start/run/msconfig/and turn SERVER4PC .After restart PC go to DVB configure channel and again restart .After restart open again DVB and watch channel .Sory for my bad english maybe peoples understand me what i mean . Over thank you for your help mittern8 i am delete this file csa.amd.dll maybe problem fix for a csa.amd.dll Quote
mittern8 Posted June 23, 2005 Posted June 23, 2005 Need to configure channel MHz on SETUP4PC etc, go to Start/run/msconfig/and turn SERVER4PC . Correct me if I'm getting you wrong: You meant, you turned off SETUP4PC? Usually there is no need for SETUP4PC and for SERVER4PC to run the DVBViewer - DVBViewer works independant from those applications. All you really are the drivers for the card itself. You also can unbind the card from the different networking protocols that Windows installs automatically as soon as the SS 2 is detected - there is no need for them either. After restart PC go to DVB configure channel and again restart .After restart open again DVB and watch channel . Whatever the reason was - the point is, that the prog is working now! Sory for my bad english maybe peoples understand me what i mean . We are all strangers in the most parts of the world. But I'm quite sure that on this board there are even some guys that would understand even if you'd write in russian as they used to live in the former DDR and had to learn the language of the Big (Eastern) Brother in school as we had to learn the language of the Big (Western) Brother. Over thank you for your help mittern8 i am delete this file csa.amd.dll maybe problem fix for a csa.amd.dll <{POST_SNAPBACK}> You're welcome! I'm not aware about the legal situation in Azerbaijan but using tools as csa.dll is concerned as illegal sat-hacking over here and due to this discussing of those things is banned from this board. But the situation might be different where you live. Maybe you can find some help anywehre else to make your plugins work - as I'm quite sure they should work. Quote
//*PRE|)@T()R*\\ Posted June 23, 2005 Author Posted June 23, 2005 (edited) Mittern8 i'm watch sat NSS 6 channel CNG TV and there in channel no sound i don't know how to fix that maybe you can help me And when i'm close DVBViewer and again try to join channel there again write words BC2C2 MPEG 2 !!!. I'm use LogMPEGDEcoder and have this decoders . MPEG2 Video Decoders: --------------------- Sonic Cinemaster® DS Video Decoder: 00710000 Elecard MPEG2 Video Decoder: 00700000 DVD Express Video Decoder: 00600000 MPEG Audio Decoders: --------------------- AC3Filter: 40000000 Moonlight Odio Dekoda: 24111981 MPEG Audio Decoder: 03680001 Sonic Cinemaster® MCE Audio Decoder: 00710000 DVD Express Audio Decoder: 00600000 Edited June 23, 2005 by //*PRE|)@T()R*\\ Quote
hackbart Posted June 23, 2005 Posted June 23, 2005 Hmm i just saw the pictures so Please make sure that you installed the skystar2 driver. I know MajorDVB comes with its own driver. Take a look into the device manager if the card driver is enabled! Christian Quote
//*PRE|)@T()R*\\ Posted June 24, 2005 Author Posted June 24, 2005 (edited) hackbart,Jun 24 2005, 12:57 AMHmm i just saw the pictures so Please make sure that you installed the skystar2 driver. I know MajorDVB comes with its own driver. Take a look into the device manager if the card driver is enabled! Dear Christian Sure enabled I'm watch CGN TV , test sound on the Winamp etc , sound all work on good but i have only VIDEO .Over Sound not aviable on DVBViewer don't know what the problem . Edited June 24, 2005 by //*PRE|)@T()R*\\ Quote
