reki Posted January 12 Posted January 12 I have following setup: Windows 10. MediaServer 3.3.1.0. Local Digital Devices Max S8 tuner to record DVB-S streams. Several TS Stream Device recording Internet radio. At any given time, about 40 timers programmed, simultaneously recording ~10 channels: DVB-S and Internet. The interface is sluggish, clicking on any tab (Timeline, Timers, Status, Configuration) takes >= 10 seconds to load. Sometimes freezes are much longer. Recordings seem to be unaffected, we see they come in time. The CPU stays at ~2.5% and memory usage at 180 MB. I don't see memory increase. The issue seems to be similar to my previous issue: https://www.DVBViewer.tv/forum/topic/74183-mediaserver-web-interface-extremely-sluggish/ but I tried deleting SvcDatabase.db3 and no change. Also, no elevated CPU and memory usage. support.zip Quote
Griga Posted January 13 Posted January 13 vor 9 Stunden schrieb reki: Several TS Stream Device recording Internet radio (...) The interface is sluggish, clicking on any tab (Timeline, Timers, Status, Configuration) takes >= 10 seconds to load. It is most likely caused by repeated attempts to record one or more non-working internet radio channels. There are a lot of "SetTuner failed" entries in your svcdebug.log. Probably the radio server does not reply, for whatever reason, so the tuning procedure waits until the connection timeout has elapsed (default 5000 milliseconds, see settings of your TS Stream devices). During this time the Media Server is not able to respond to other requests. It becomes a permanent issue, because the recorder tries again and again to start a recording of this channel, until the timer end time is reached. There are two measures that have to be taken. One is up to you, the other one up to me: You need to clean up your timer list and make sure that it only contains timers for radio channels that are working reliably. I have to think about measures that avoid such uselessly repeated recording attempts, e.g. by letting the recorder give up after a certain number of failed attempts, or retry tuning only once per minute. I will let you know as soon as I have a solution for it... 1 Quote
Griga Posted January 20 Posted January 20 Now I have some time to look after this, but I'm a bit unsure how to handle it. Basically there are four possibilities: Drop the recording, if tuning fails, without further attempts to start it. This could cause a temporary delay in the web interface, but only once per timer. Drop the recording after a limited number of x tuning attempts, hoping that the channel will become available within x seconds. This could cause a longer temporary delay in the web interface, but only once per timer. Retry to start the recording once per minute (or some other interval), hoping that the channel will become available again sooner or later. However, this could still make the web interface sluggish every now and then, particularly if tuning fails for more than one timer. A combination of 2. and 3, hoping that the channel will become available within x minutes. Am 12.1.2026 um 19:42 schrieb reki: At any given time, about 40 timers programmed, simultaneously recording ~10 channels: DVB-S and Internet. What would you prefer from your experience as as "power recorder"? Quote
reki Posted January 20 Author Posted January 20 Thank you for the response, I think the approach (4) is fine. In our situation, we need to maximize the amount of recorded minutes. But I'd like to stress the discoverability of the problematic channels. I just viewed the Status tab: I noticed when there are just 8 DVB-S tuners active, the delay is ~10 seconds. When 8 DVB-S tuners + 9 radio stations from the Internet, then the delay is ~17 seconds. svcdebug.log is full of SetTuner failed messages, but there is just info about tuning: Quote TType: 6, Freq: 0, Symrate: 3214561302, LOF: 46791, Tone: 9, Pol: 0, DiseqC: 0, FEC: 1, APID: 257, VPID: 256, PMT: 4095, SID: 1, TID: 1, NID: 0, SatMod: 0, DiseqCVal: 21753, Flags: 24, Group: 0 Can this log be made more human-readable: show the station and exact Timer, which causes it? The good solution would be also informing about the tuning failings in the web interface. I think the info should show the channel and the timer which causes the tuning to fail. The perfect solution would be making the web interface asynchronous regarding the tuning and other long-lasting processes, but I guess it a great amount of work. What do you think? Quote
Griga Posted January 21 Posted January 21 vor 17 Stunden schrieb reki: Can this log be made more human-readable: show the station and exact Timer, which causes it? I'll have a look at it. vor 17 Stunden schrieb reki: The perfect solution would be making the web interface asynchronous regarding the tuning and other long-lasting processes, but I guess it a great amount of work. The tuning should be asynchronous. It would be a great amount of work, because it would require a fundamental structural change in the DVBViewer and Media Server code base. That's why I'm looking for a short-term solution, maybe not optimal, but something users can live with. Quote
Griga Posted February 6 Posted February 6 @reki The following solution would now be available as test version for you, if you want to try: Change: Recorder: Measures against an unresponsive Web Interface caused by repeated unsuccessful TS Stream tune attempts, because the server does not respond. Now the recorder repeats them only once per minute (previously as soon as possible) and deactivates the timer after a number of unsuccessful attempts (or switches timers with weekly repetition to the next date). The number is specified by the new tweak “Max. tune attempts on TS Stream timer recordings. The default is 3 (→ launch DMSTweaker.bat). Quote
Griga Posted February 7 Posted February 7 I've added you to a personal message where you can download the test version. The forum software should inform you about it. I've also enhanced the logging a bit, so you can see in the svcdebug.log which channel could not be tuned. Quote
reki Posted February 15 Author Posted February 15 Hello, I run the beta version for several days. It seems that the web interface got faster. So far, no problems. Quote
Griga Posted February 15 Posted February 15 vor 4 Stunden schrieb reki: It seems that the web interface got faster. Still with attempts to record internet radio channels that can't be tuned due to a missing server response? Please note that the changes only apply to internet channels, not to DVB (could be implemented as well). Quote
reki Posted February 19 Author Posted February 19 I think there is another bug, the service crashes with Bad CRC: 18.02.26 14:09:30.268 TServiceMain AddReference WebMain: 2 18.02.26 14:10:00.170 TServiceMain ReleaseReference WebMain: 1 18.02.26 14:10:30.738 TServiceMain AddReference WebMain: 2 18.02.26 14:11:00.810 TServiceMain ReleaseReference WebMain: 1 18.02.26 14:11:35.418 TFileDevice CheckAutoRetune Retuning TS Stream Device 10 18.02.26 23:00:08.887 ParseSI Bad CRC So far it happened twice, but the first time was when the disk was full, so I thought it was because of that. It required manual restart. Quote
Griga Posted February 19 Posted February 19 vor 3 Stunden schrieb reki: the service crashes with Bad CRC: "Bad CRC" is quite normal, and it's unlikely that this causes a crash. "Bad CRC" simply means that the CRC32 checksum of broadcasted Service Information data (mostly EPG) didn't match, which means, the data is somehow corrupted and therefore discarded by the Media Server. SI data is an important part of DVB streams and always CRC32 protected, enabling receivers to detect if it is not ok. You can read more about it here. What are the symptoms of the crash? Quote
reki Posted February 19 Author Posted February 19 I observed the service stopped recording. The last recording was completed on 18.02.2026 at about 14:17. *svcrec.log* matches the files in the recording directory. The log went silent after 14:11, only this single Bad CRC line. I don't know if the interface worked at that time. I noticed the crash today at 8:00, the interface wasn't responding (timeout, not connection refused). I restarted it and it went back to normal. I attach the full svcdebug.log, maybe there is something relevant here I cannot spot? I've got a limit of the files uploaded (35 kB), so I put it on Dropbox: https://www.dropbox.com/scl/fi/43p0f17p8p3m1ln3uipck/svcdebug.log?rlkey=eg6bkjyj69lv13b82b6zyi4d3&st=bdo9sz4c&dl=0 Quote
Griga Posted February 21 Posted February 21 Am 19.2.2026 um 19:12 schrieb reki: I've got a limit of the files uploaded (35 kB), so I put it on Dropbox: You may want to delete old attachments - click your user name at the top right of the forum. There is a menu item for managing your attachments. Am 19.2.2026 um 19:12 schrieb reki: I attach the full svcdebug.log, maybe there is something relevant here I cannot spot? There is! Zitat 18.02.26 13:58:14.201 TRecording StartRecord 89.0 RTL Livestream with TS Stream Device 10 //... 18.02.26 14:11:35.418 TFileDevice CheckAutoRetune Retuning TS Stream Device 10 // <== 18.02.26 23:00:08.887 ParseSI Bad CRC CheckAutoRetune means, no data arrived for 5 seconds, so the virtual TS Stream Device 10 (here also labeled "File Device") tried to re-establish the network connection, assuming that it got broken somehow. However, there is something supposed to follow in the log, as other retuning in your log shows, for example Zitat 17.02.26 21:31:52.114 TFileDevice CheckAutoRetune Retuning TS Stream Device 2 17.02.26 21:33:50.147 TFileDevice StopDevice 17.02.26 21:33:50.147 TFileDevice CloseDevice Since this is not performed by TS Stream Device 10 after the retuning was triggered, there is evidence that stopping or closing the device caused the crash, for whatever reason. It blocked the Media Server's main thread, so it didn't work any more. The Bad CRC entry originates from another thread (the streaming thread receiving DVB/network data), so there was still some reception going on in the background several hours later, maybe due to a recording that the main thread couldn't stop anymore in time. Unfortunately it is hard to spot why and where the blocking actually occured, maybe in the Media Server code, maybe in the underlying network library, or even in the Windows Winsock2 implementation or the networ adapter driver... maybe it only happens rarely due to certain timing conditions, so it can't be reproduced easily. I think what we can do now is I can investigate thoroughly if something can be found in the Media Server's TS Stream code that may cause such a blocking. May take some time... Since you now know what to look for, you can observe if this kind of crash happens again. You can consider if you really want/need this retuning mechanism. It can be configured for TS Stream Devices that have been manually added to the Media Server's device list - see Hardware -> Retune on missing stream... The default is 5 seconds, the value 0 disables auto-retuning for a device. Quote
reki Posted 5 hours ago Author Posted 5 hours ago I monitored the Mediaserver for couple of days and I'm suspecting the hardware issue. Killing the Mediaserver from the Task Manager results in the Windows system restarting. The temperatures of my Digital Devices Max S8 seems too high (55 degC). RAM is OK according to Memtest86. I'm going to attach heat sinks to these cards and test it for couple of days. I'll report afterwards. Quote
