Can't record HTTP Live Streaming
suandsu
Hi all,when recording a HTTP Live Streaming, I ran into a problem: I ONLY can play this URL as file, but when I start recording, nothing gets recorded.Could you please tell me if there is any way to properly record the video stream, including both audio and subtitles?The URL is http://o11.163189.xyz/stream/tvb/fct4k/image.thumb.jpeg.82b3cbe9df86bfe724679c8acff7a5f3.jpeg
vor 13 Stunden schrieb suandsu:
Thanks for the report. It revealed a bug in DVBViewer concerning the handling of relative URLs. Will be fixed in the next release.
You can work around it by adding another slash to the URL, so it becomes
http://o11.163189.xyz/stream/tvb/fct4k//
and removing the "Play as file" checkmark (-> Apply). Please note that the stream contains no subtitles, only video and two audio tracks. If you want to record all audio tracks of such streams, you may need to launch Tweaker.exe from the DVBViewer program directory and tick "Receive all audio tracks of HLS streams".
  • Thanks 1
