Hell_Angel Posted July 9, 2005 Posted July 9, 2005 (edited) I would like to see this device working in DVBViewer Pro or does it work in it already? Edited July 13, 2005 by Hell_Angel Quote
Klausing Posted July 15, 2005 Posted July 15, 2005 never heard something about this digital device. Could you post a link or specification which chip etc ? edit: you mean this: http://www.inventa.com.au/Product%20Releas...ent/FireDTV.htm ? Quote
Klausing Posted July 15, 2005 Posted July 15, 2005 WDM and BDA drivers are available for wide range of third-party TV tuning application With one of this driver should the DVBViewer working... Quote
Hell_Angel Posted July 21, 2005 Author Posted July 21, 2005 Yes it's that device. I think official page is http://www.digital-everywhere.com. You should find there all information you need. Quote
Hell_Angel Posted November 20, 2005 Author Posted November 20, 2005 Does FireDTV DVB-C work in DVBViewer now? I noticed that DVB-S is supported. If it's not, is it going to be supported? and if it is, when? Quote
Griga Posted November 20, 2005 Posted November 20, 2005 FireDTV-S works, but we are still fighting with a few issues. See here and here. Quote
Hell_Angel Posted November 21, 2005 Author Posted November 21, 2005 Ok. Good to hear, that you guys are working on it. Quote
Griga Posted November 21, 2005 Posted November 21, 2005 I'm quite sure that DVB-C will work, since DVB-S is the most difficult among BDA reception types. The remaining issues seem to be DVB-S specific. Did you try TransEdit MMC from the public download area? Quote
Hell_Angel Posted November 28, 2005 Author Posted November 28, 2005 I have already buyed DVBViewer about year ago. I had Twinhan card then, but I can try that new version of DVBViewer with my FireDTV DVB-C box. I'll inform you later did it work or not. Are you planning to do remote control support for these cards? Quote
