DVBViewer Update
hackbart
Since the release of the DVBViewer Pro 3.2 was over-due - it had been announced for release some weeks ago - we did our best to publish it before the summer holidays.
For more refer the link:
Now we proudly announce a new release of the DVBViewer Pro that again proves that lots of features and stability at the same time is possible.
As a result of our close co-operation with Twinhan now all of their cards will run as stable as the SkyStar 2.
Additionally the DVBViewer Pro now acts as a COM-server which provides a wide range of new possibilities.
For example you can now request teletext pages comfortably within Excel or Word, furthermore you can read and program the OSD.
At last we optimized the skin engine (both OSD and windowed skin), that was long due because of a lack of performance.
Therefore we gladly announce a competition for the OSD design skin, which is solely done by our own skin-editor. Information on prizes and
details will be disclosed in the next days. The skin-editor is freely available and restricted to be used with the DVBViewer.
Following there is a complete list of changes in the new release:
  • Add: COM: added freedb and mp3tag reading to COM-Server.
  • Add: COM: integrated COM-Server (ex-COM-Plugin) into DVBViewer.
  • Add: Controlling: Added MiniEPG
  • Add: Controlling: Added Next Song
  • Add: Controlling: Added Playback faster
  • Add: Controlling: Added Playback slower
  • Add: Controlling: Added Prev Song
  • Add: Controlling: Added Show Currentplaylist
  • Add: Controlling: Added Show Musicplaylist
  • Add: Controlling: Added Show Videoplaylist
  • Add: Controlling: Added Toggle Zoom
  • Add: DVD-Playback: last position of DVD-Playback is now remembered for every DVD
  • Add: Options: InstantEPGoffset for EPG calculation of an instant recording.
  • Add: OSD: Added "only Favourites" filter to contextmenu in EPG Now and Timeline
  • Add: OSD: Added MiniEPG to contextmenu when timeshifting
  • Add: OSD: Added Next Song to contextmenu when mediaplayback from playlist
  • Add: OSD: Added Prev Song to contextmenu when mediaplayback from playlist
  • Change: Internal: Some changes of internal structures for COM-serving
  • Change: OSD-Controls: Some small fixes and changes
  • Change: OSD-Musicfiles: The tracks of an autoplayed audioCDs get now a titel (instead of track1 etc), if audioCD is present in the mediadb (for now no freedb query for autoplay cds, only if selected via osd-musicfiles)
  • Change: OSD: Adding file to playlist in Video or Music window only moves the selection down instead of putting it at the top
  • Change: PluginInterfaces: Some small fixes and changes
  • Change: VCR: Instantrecordings now calculate the epg on start with the time recordstart + InstantEPGoffset to compensate wrong EPG with "early" recordings
  • Change: VCR: some changes for updated audiorecorder plugin
  • Change: VMR: Changed VMR detection with scambled channels
  • Change: Winlirc: Changed handling of Winlirc, double keypresses should not occur anymore.
  • Fix: DirectX: added missing stop to graph construction, caused hang-up while recording and switching channels
  • Fix: DirectX: format detection
  • Fix: Options: Shutdown: Default Shutdown Action didn't work
  • Fix: OSD-Musicfiles: Autoplay audioCD didn't work until the OSD-Musicfiles were once opened.
  • Fix: OSD-News: Urls with forbidden characters resulted in non download of the data.
  • Fix: OSD-Playlist: Currently playing item is now updated correctly
  • Fix: VCR: Deleting a Timer could cause afterRec action to trigger
  • Fix: VCR: If an instant recording and a timer recording are running on the same channel pressing the recordbutton caused both recordings to stop instead of only the instant recording
  • Fix: VCR: If capture path is missing all recording will be stopped and an alert will be displayed
  • Fix: VCR: Starting Recording stops Mediaplayback
  • Fix: OSD-Timerlist: Timers with the same date and time: only one was shown the rest ignored.
  • Add: OSD: Added theComputer page, a simple fileexplorer
  • Add: Controlling: Added theComputer page
  • Add: OSD: Simple Helpsystem callable via contextmenu.
  • Add: OSD: Alphanumeric virtual Keyboard for input
  • Add: OSD: Numeric virtual Keyboard for input
  • Add: OSD: Simple alphanumeric virtual Keyboard for input
  • Add: OSD: File/folder selction dialog
  • Add: OSD: Simple bookmarks handling for every mediatype (callable via contextmenu in mediapage and main osd menu)
  • Change: OSD: Reworked the mediapageskin
  • Add: OSD: Added coverart to the mediapage
  • Change: OSD: OSD-Blue now calls on every osdwindow the contextmenu
  • Add: OSD: now coverart is displayed, the system searches for a file called folder.jpg in the current and one level deeper folders
  • Add: System: scripts can be executed internal on the following events: windowload, stoprec, startrec, action (a unknown command is passed to the script), channelchange
  • Add: System: a internal executor-engine, capable of executing apps, scripts, cmd, functions, hyperlinks, can be accessed by scripts and plugins
  • Add: System: a internal timer-engine, capable of firing timer events that can execute apps, scripts, cmd, functions, hyperlinks, can be accessed by scripts and plugins
  • Add: OSD: Playlistwindow: display of coverart.
  • Add: OSD/System: Mosaic preview, displaying a preview of all channels of a transponder on one page. Channel can be selected via mouse or keyboard/remote control
  • Add: Options: A optionspage for the Mosaic preview
  • Change: OSD-engine: The rendering stages of the pages reworked, now much more flexible
  • Remove: OSD-engine: Removed the old input dialog
  • Change: OSD-engine: Optimized internal pages.
  • Add: OSD: Videosettings page
  • Add: OSD: frontend for timer-engine (theAlarms) page
  • Update: OSD: language files
  • Add: System: internal small networkstreaming server
  • Fix: VCR: detection of running vrp recordings optimized
  • Add: Database: added timer database for timer-engine
  • Add: Database: added bookmarks database
  • Add: Database: added settings database for plugins/scripts for persistent storage of information of any kind.
  • Change: Database: optimized database handling.
  • Change: OSDSkin: reworked / optimized several skinpages
  • Fix: System: changed handling of AV-disable calls from plugins
  • Fix: OSDMedia: Fixed autoplay of VCD and SVCD
  • Change: OSD: in Video-, Musicfiles and Picture pages OSD-Yellow now jumps a folder-level up.
  • Change: OSD: Changed look and optimized behavior of select-onebuttons
  • Add: OSD: Added Show playlist to contextmenu when mediaplayback from playlist.
  • Add: Controlling: Added command for toggeling the background on/off.
  • Change: OSD: Background now will never be shown if deactivated in the options.
  • Add: Controlling: Added commands for the different shutdown possiblilities.
  • Add: Scripting: Added a bunch of stuff there :ph34r:
  • Change: OSD-System: changed logging. Important error messages are now logged to osderror.log. Set logging level in Options to 90 to receive only errors.
  • Change: OSD-System: changed internal message system, now data of any kind can be exchanged via messages (important for plugins / scripts)
  • Change: OSD-System: changed internal message queue completely.
  • Change: RecorderWindow: If no endtime is given but a starttime while creating a new Timer the Endtime will be set equal the starttime.
  • Change: OSD: Playlist: OSD-Red toggles the listview.
  • Change: OSD: Slideshow: OSD-Green now calls the video Info (former OSD-Blue) and OSD-Blue now calls the Contextwmenu.
  • Change: OSD: Music: If sorted by title the display will be now TrackNo-Title-Artist.
  • Change: OSD: Playlist: OSD-Green now shows the former window (music/video) with the folder correct folder.
  • Change: OSD: Pictures: OSD-Red now adds the current folder to a slideshow, if the selected item is not a folder, or if the selected item is a folder the pictures in the selected folder.
  • Add: System: Options: Added a option to adjust the displaytime of the close warning in case of timeraction. 0 disables the warning complete.
  • Change: OSD: Imageviewcontrol: Now the text ist shown without endellipsises.
  • Change: OSD: Listcontrol: Now the text ist shown without endellipsises.
  • Fix: VCR: Nextrecordingin: Added missing () to the calculation. Now the "don't close if recording in" should work.
  • Change: VCR: Reworked code to simplify handling and avoid deadlocks / reentrance problems.
  • Fix: VCR: disabled Timers are not considered anymore when searching for the next timer.
  • Add: OSD: Mousewheel now can scroll the menus and lists, but only if the mouse is above the list, otherwise the selected default action is taken.
  • Change: StartUp: Optimized startup sequence should be a little bit faster now.
  • Fix: Options: Fixed tab-key order in all pages.
  • Fix: Options: MusicTags: fixed a minor bug in the retrivial of the musicshares.
  • Add: OSD: Slide-Control: Added mouseclick for value adjustment.
  • Add: OSD: Slide-Control: Added mousewheel for value adjustment.
  • Add: OSD: UpDown-Control: Added mousewheel for value adjustment.
  • Add: COM: Volumeproperty: Float 0..1 read/write.
  • Add: COM: LoadFromFile.
  • Add: COM: GetBookmarks.
  • Add: Controlling: Added command AddBookmark.
  • Add: OSD: Progress-Control: Added Mouseclick for value adjustment.
  • Add: OSD-Settings: Added pictures setting page.
  • Add: OSD-Settings: MusicSettings: Added Start Vis, Shuffle Playlist and Loop Playlist.
  • Change: OSD-Timeline: Changed ColorKeys and Context-Menu to match the application wide scheme.
  • Change: OSD-EPG-Program: Changed ColorKeys to match the application wide scheme.
  • Change: OSD: Base Homewindow now can also have a videowindow (and a background)
  • Add: OSD: Completely new Channellist window.
  • Add: Preview, completely controlable by mouse and keyboard.
  • Change: System: Completely reworked generation of videothumbnails.
  • Add: Clicking on the left side of the DVBViewer window shows the Channellist.
  • Add: Clicking on the lower side of the DVBViewer window shows the MiniEPG/Mediawindow
  • Change: EPG: Completely reworked EPG-engine by Griga. Now epg is even faster than before.
Christian
I forgot to mention, for twinhan it might be necessary to use the latest driver updates.
Christian
