ARTE reception
marsh.rousseau
I have just installed DVBViewer full. I use it for ASTRA with a Skystar 2. I seem to have a problem with ARTE. The image freezes after a few seconds, whereas the other channels are fine (like TV5). Any ideas???
Thanks
If I use LogMPEGDecoder, I get this:
MPEG2 Video Decoders:
Sonic Cinemaster® DS Video Decoder: 00710000
Elecard MPEG2 Video Decoder: 00700000
MPEG Audio Decoders:
Moonlight Odio Dekoda: 24111981
MPEG Audio Decoder: 03680001
Sonic Cinemaster® MCE Audio Decoder: 00710000
This are not all needed informations
I use DVBViewer V3.1.0 with windows 2000 SP4.
Basically, most of the time I can view ARTE for 2 to 3 seconds before it freezes, sometimes to image at all. Other free channels seem to be fine. What do you need to know about my congiguration?
Thanks!
  • 3 weeks later...
is your signal ok?
is arte maybe the one with not enough Signal + Quality
so your dish or kabel is the problem ?
I did a new CHANNEL SCAN and it seems to be OK now. They must have changed something recently. Thanks all for your help...
