problem with lower resolution channels
max9998
When I watch channels that have horisontal resolution less than 720 pixels I get black border on the right side of the screen and the picture is horisontally squeezed. That happens in the fullscreen also. How to force picture to take up the whole screen (I can do that with the sliders but then normal channels get screwed up).
Probably you have the Elecard MPEG codec active!
You need to deinstall it!
ciao
