aydan Posted July 14, 2005 Posted July 14, 2005 Hi, it's me again. Bugs seem to like me. I had two recordings going: Pro7 22:10-22:45 K1 22:10-23:25 the Pro7 one went ok, but the K1 recording aborted when the Pro7 recording finished, although i was still marked active in the Recordsettings window. Quote
aydan Posted July 15, 2005 Author Posted July 15, 2005 No, I use the standard recording mechanism. Quote
aydan Posted July 15, 2005 Author Posted July 15, 2005 Now this I don't understand. Why would I want to use a plugin if this feature is supported and usually working. I just pointed out that it happend to me once and it might happen again, so the devs can have a look into it and might be able to find out what happened and solve the problem. Using a plugin is only a workaround, and I don't like those, because they don't really improve the program. Quote
admi-ral Posted July 15, 2005 Posted July 15, 2005 well, if it happened "only" once, you might try to reproduce it a couple of times maybe you install a "clean" copy of DVBViewer in another directory and figure out if it happens again... Quote
