vic20 Posted July 15, 2005 Posted July 15, 2005 I have done a clean install of the new DVBViewer 3.1.2 and after i have scanned the channels with Twinhan DVB-T CI it finds all the channels fine and everything works ok. Then i delete all the other satellite-transponders and everything is still great. But when i quit the program and restart it all my DVB-T-channels are gone and all the satellite-transponders and channels are back. Any sollutions? Otherwise this program is starting to work great. Quote
Griga Posted July 15, 2005 Posted July 15, 2005 Which means, DVBViewer didn't re-write the file channels.dat. Write-protected? Missing access rights? Quote
Gioxy Posted July 15, 2005 Posted July 15, 2005 I also haved the same problem, and channels.dat isn't write protected and I haved try to set ALL access right for ALL users and groups to that file, but it's still the same... The way I worked out is to completely delete the channels.dat file and to import the channels via a file .ini created with Griga's TransEdit... But it's sad that so far I've lost the useful folder structuration by language... also I have to completely rebuild the Favourite list... Quote
Jiini Posted July 16, 2005 Posted July 16, 2005 I also haved the same problem, and channels.dat isn't write protected and I haved try to set ALL access right for ALL users and groups to that file, but it's still the same... Same thing happens also here, terrestrial channels disappear after exit... Quote
daffy Posted July 17, 2005 Posted July 17, 2005 Which means, DVBViewer didn't re-write the file channels.dat. Exactly this is happening to me - any modification whatsoever to the Channel list gets lost the moment I terminate DVDViewer. This is Not Good. Write-protected? Missing access rights? Ummm. It is a completely fresh installation, after all - Windows XP SP2, all current updates, NTFS drive. [Plus I removed all write-protection and removed all permissions and added every single permission for "Everyone" ("Jeder")] Things are working rather well with version 3.1, for what it's worth... Quote
Gioxy Posted July 18, 2005 Posted July 18, 2005 ...I forgot to mention that after the operation I wrote it work well... Maybe in the original channel list there is some kind of problem that cause the v. 3.1.2 to exit immediately without rework the channels db: normally I get a CPU usage peak after closing DVBViewer, that with the original v. 3.2.1 channellist I can't notice... Quote
vic20 Posted July 18, 2005 Author Posted July 18, 2005 Solved. I just deleted the channels.dat and did a new channel search and then it worked. Quote
