Jiini Posted July 16, 2005 Posted July 16, 2005 One minor bug with 3.1.2. The signal strenght in status bar is always 0%, even if the signal is 90-100% (this is seen with 3.1 version). Quote
Timer Posted July 17, 2005 Posted July 17, 2005 hallo, i have the same problem! In 3.1.2 it shows allwasy 0% signal, but the video and audio is ok. Timer Quote
Gioxy Posted July 18, 2005 Posted July 18, 2005 Oh, maybe you don't know, but the signal bar offer 4 info: the signal strenght, the actual play time in % and in minute and the remaining play time (but only if the prog have the EPG info). You can simply left clic on it to change it... Quote
Guest Oliver Posted July 18, 2005 Posted July 18, 2005 @Jiini and Timer: Do you use an Airstar? With an AS2 I can confirm this behaviour. Quote
Jiini Posted July 18, 2005 Author Posted July 18, 2005 @Jiini and Timer: Do you use an Airstar? With an AS2 I can confirm this behaviour. <{POST_SNAPBACK}> Yes, Airstar 2. Quote
Timer Posted July 18, 2005 Posted July 18, 2005 I know that a left click change this! No, i have a technisat Skystar2. In the Directx menü i have skystar selected. In TE it was allways ok. Timer Quote
Guest Oliver Posted July 18, 2005 Posted July 18, 2005 Hm, I can only confirm it with an AS2. With SS2 everything's fine here. Quote
Gioxy Posted July 19, 2005 Posted July 19, 2005 Also here... ...except that the very first time I started DVBViewer 3.1.2 (after a clean installation) the bar was showing something different from the signal strenght... Quote
