aiwa2001 Posted July 17, 2005 Posted July 17, 2005 Hello! Thanks for the 3.1.2 version, seems to work beautifully! However dvbserver still has one bug. My server starts dvbserver through task scheduler but only one DVBViewer client pc can connect and get picture. If I go to server and open up the dvbserver window and check unicast clients number it says 4 which is correct. But to get the 4 clients working I have to manually change the client number to 5 and back to 4 and press ok. After this every client can connect correctly... I hope this gets fixed someday. Is there any commandline options to dvbserver.exe so I could avoid the problem? Quote
