Using another MPEG2 codecs
Lovec
With WinSTB expiriments , which can be used with any codecs building your own filter graph i have to try lot of codecs and I get this results.
The quickest was codec from PowerDVD,
second was codec from NVDVD but has a best picture quality,
DVD Express codec was not the worst ...
So .. can it be possible to make DVBViewer working with another video and audio MPEG2 codecs, may be asi in winSTB 0.88 using filter graph?
Edited by Oliver
Thats a realy good feature and i have made the same experience. Also the CPU usage was more fewer as with other codecs. I would be fantastic if we could build our own graph in graphedit --> put it in filterdirectory --> DVBViewer use this graph.
Guest Michael
if i heared it the right way ... hackbart said that DVBViewer is only working with the dvd express codec atm... and other codec support will be implemented after the XVR support... which will make it possible to do so
just a question for my understanding since I am very new to all this stuff.
To convince DVBViewer to use other codecs/filters you just have to
1) open the graphedit tool
2) build the graph you want to have
3) save the graph into the /filters directory of DVBViewer
and upon the next start of DVBViewer it will use the graph you just built, correct?
rgds chaag
Not at this time but we want that he do it :rolleyes:
rgds chaag
Yes may by so. Then it will be possible to add for example VobSub filter, and simple subtitles support will be ready :rolleyes:)
