casi Posted January 16, 2003 Posted January 16, 2003 (edited) would it be possible to extend the channel info by adding ecm? this would make the channel list more consistent with other lists. thanks. Edited June 18, 2003 by Oliver Quote
Guest Michael Posted January 16, 2003 Posted January 16, 2003 would it be possible to extend the channel info by adding ecm?this would make the channel list more consistent with other lists. thanks. ecm is only needed for encrypting channels.... and DVBViewer doesn't offically support paytv... threfore it isn't needed... Quote
Unauthorized Posted January 16, 2003 Posted January 16, 2003 Well, you will only need ECM for the reason Michael mentioned. For that, you will have to find another way. And why should Christian integrate a feature that isn't needed? I would be happier about support of AC3 pids as I asked in another thread. Quote
