egbert Posted July 20, 2005 Posted July 20, 2005 Bug Report 3.1.2 1. "Show Ongoing Recordings" is out of order (always). 2. Timer Recordings don't change the colour of the record button any longer. Quote
Guest Lars_MQ Posted July 20, 2005 Posted July 20, 2005 2. Timer Recordings don't change the colour of the record button any longer. Thats correct, only a instant (manual) recording activates this button, cause only a manual recording can be stopped with this button. 1. "Show Ongoing Recordings" is out of order (always). Works for me , as soon as i switch to a channel a recording is running the recording OSD symbol is shown. You have to activate it in the options. Quote
egbert Posted July 21, 2005 Author Posted July 21, 2005 1. "Show Ongoing Recordings" is out of order (always). Works for me , as soon as i switch to a channel a recording is running the recording OSD symbol is shown. You have to activate it in the options. <{POST_SNAPBACK}> That wasn't the problem. You must have OSD active, too. This should be added to manual! BTW: There should be a sign if a recording (or timeshift) is running... Quote
