RecordingTimeshift should be signaled
egbert
I would like to see if a recording/timeshift is running by first look...
At now (3.2.1) you can only detect a recording if you look the same program you are recording. If the recording was started by timer you must have OSD and "Show ongoing recording" active to see it.
A running timeshift is never shown.
This is not bad in my oppinion.
See, timeshift is running most of the time by default anyhow, so there would always be a kind of symbol blinking?
If you have a look at FILE, there is Timeshift, and when timeshift is aktivated, there is a marker, isn´t it?
;) *I* don't run timeshift on default...
