Guest Lars_MQ Posted July 22, 2005 Posted July 22, 2005 I uploaded the help file for the DVBViewer COM Interface. Some things aren't described completly for now but I keep on working on it. Questions/suggestions as always are welcome. have fun lars Quote
Guest Lars_MQ Posted September 18, 2005 Posted September 18, 2005 I added an Update of the Interface Doku for the new DVBViewer Pro Version. You can find it in the Membersarea -> sources. lars Quote
oaks Posted September 18, 2005 Posted September 18, 2005 (edited) hello lars, i have a problem downloading the com interface doku: the file seems to have no extension, it is named only 'DVBViewer'. inside the file i found this text: 'DVBViewer COM Interface.chm', so i renamed it accordingly. but opening it still gives me an error: 'Cannot open the file: mk:@MSITStore:T:\Download\__new\DVBViewer COM Interface.chm' nb: using firefox on winxp pro multilang eng sp2 bye, oaks. Edited September 18, 2005 by oaks Quote
oaks Posted September 18, 2005 Posted September 18, 2005 found the problem. it's a problem of firefox downloading files with spaces within but renaming them to the first part. bye, oaks. Quote
Guest Lars_MQ Posted November 5, 2005 Posted November 5, 2005 Here the preview version of the new COM Interface documentation. Hier eine Vorabversion der COM Interface Dokumentation für den DVBViewer 3.2.5+ Lars Quote
daffy Posted January 29, 2006 Posted January 29, 2006 Here the preview version of the new COM Interface documentation. Is it possible that this update never made it into the members area? There, I still see » Description: DVBViewer COM Interfaces ( 647 Downloads ) » Version: Docs for DVBV 3.2.2+ » Size: 130 KBytes » Last Updated: 18.09.05 Quote
Guest Lars_MQ Posted January 29, 2006 Posted January 29, 2006 It's problematik to keep the overview, I think christian put ist somewhere in the downloadarea of www.DVBViewer.com. I check it out and try to get all in sync, as soon as I have a little more time Quote
Guest Lars_MQ Posted June 19, 2006 Posted June 19, 2006 I updated the COM doku in the membersarea. Only minor changes in there. Christian will update the docu on the Downloadpage of www.DVBViewer.com Quote
disaster Posted April 14, 2008 Posted April 14, 2008 Is it planned that the SDK will be a little bit more explained? What eventmsg's does exist? Which commands can i send via sendmessage? etc. Quote
Valts Posted September 10, 2008 Posted September 10, 2008 Would be great to have full up to date documentation/SDK. Since judging from some available sources there's a substantial amount missing from docs and from TLB. Quote
Findus Posted October 16, 2008 Posted October 16, 2008 I fully agree! I also would like to implement a COM based add on program. Unfortunately it´s very hard to use the COM interface because the documentation is very limited. I already spent a lot of time to figure out what the different classes and methods are doing. So Hackbart and Lars please spend some time to fix this. Having more application available will also help DVBViewer! Findus Quote
