Channel Editor
nokver
hello I bew on dvdbiewer ..:rolleyes:
Any say me if exist an channel editor to make a owner list with the label ... and more....??
Tks
Well a quicker and better channel list editor would be handy. :rolleyes:
You can create in channel list a new channel on the edit tab (with own name and own category and own root if you wish) click on ADD and thats it. If you want to have it on an other directory take it with drag and drop to an other directory.
What is ther difficult or not easy?
Guest Michael
can you give me an example for a handy channel list?
Hi
My problem is edit the channel disecq ..... make one to one is more bad
I ask if it's a program like the channel editor for decoder to work on the list channel file ....
tks
Hi
Mark the Satellite you will change the disecq and go to edit
now you can change disecq for all channels in one click.
lukyluke
