FrankSk Posted July 28, 2005 Posted July 28, 2005 I have recently bought and installed a Skystar 1 CI. As I am not to happy with the OEM software (especially the manual) I am thinking about buying another DVB software. As I am also considering the DVBViewer, I wanted to ask if anyone does already have any experiences in operating the two together. In particularly, I would like to know if I have to remove the other OEM software from the system and if the DVBViewer itself is easy to setup (Astra 1 and Astra 2) ? Thank you for any comments! Quote
Klausing Posted July 28, 2005 Posted July 28, 2005 what kind of skystar 1 ? The verry old one or the new one? Quote
yaRincewind Posted July 28, 2005 Posted July 28, 2005 The SkyStar 1 CI should be the TwinHan CI DVBs (something about 100€ or cheaper) (NOT the Technisat one ~220€) Since the latest Version 3.2.190 this modell is supported and supposed to be working without any problems (in 3.1 it didn´t work properly) The OEM Software can be installed on the PC, but you need to install the DVBViewer Pro in a new directory, otherwise you will run into problems. Also, if you use the OEM version after isntalling the PRO, you have to execute a small programm in the 3.2.190 DIrectory), just have a small look in the manuall The setup is quite simple. Install, start, selecting your card (in the directX properties), the codec to be used, switch to a channel and enjoy the show Quote
FrankSk Posted July 28, 2005 Author Posted July 28, 2005 Thanks for for comments. Yes it is the newer version, costs around € 90. I will give it a try ! Quote
