Transedit Problem
I use Transedit everyday and export my channels to DVBViewer without any problems. However over the past couple of days some channels are appearing in Red type and once in DVBViewer I am unable to see the image. I am assuming that Red means some sort of encoding that DVBViewer cannot decode. If this is the case can someone outline how I can find out what decoder is required. If it isnt the case perhaps someone can explain what the Red actually means.
Thanks
Griga. Thanks for that. You're quite right and I should have read the manual. Pretty obvious really, so I apologise for that and will remember next time.
While I'm here, is there any way I can find out what encryption is being used by using any software or do I need to go to the providers to find out ?
Thanks
