BDA support?
Harryo
I have just purchased DVBViewer Pro to see if I could get it to work with my Twinhan Alpha USB2.0 device using the Twinhan BDA driver.
The Alpha does not appear to be recognised by the DVBViewer software and I seem to recall reading somewhere that the software does not work with USB Twinhan devices only PCI ones.
The BDA driver is used with Twihan's DTVision software and also MyTheatre software without any problems but I would much prefer to use DVBViewer Pro which comes highly recommended on another forum! -- (ie:- "you will get one of the best applications in the market, with features that most other applications dream about")
On this particular forum it also mentioned that "BDA drivers are being developed", although it did not mention by whom.
Hopefully I will be able to use DVBViewer sometime in the future. :bye:
Harryo
Guest Oliver
A BDA version will be officially released after some legal considerations. Technically there is no problem.
Thanks for the update Oliver, that is excellent news! :bye:
Harryo
