bibi Posted August 11, 2005 Posted August 11, 2005 Since I've installed the new version, the EPG list often does not load at all or incompletely. Any advice what to do? Brigitta
admi-ral Posted August 11, 2005 Posted August 11, 2005 yes! Describe exactly (!) what happens/you do after (re-)installing the applications in a new directory and deleting all other sat-positions except the one you are using (only for testing). you know that the channel of the epg-data you wish to browse has to be tuned befor?! tried to delete the epg.dat?
