pe3k Posted August 14, 2005 Posted August 14, 2005 Hi, after I set all the recordings and turn off and on the DVBViewer all the scheduled recordings dissapear... and also after updating to version 3.2.1 I get no OSD - it just isn't working Quote
Guest Lars_MQ Posted August 14, 2005 Posted August 14, 2005 Make sure you have the needed user rights in the DVBViewer folder. For the OSD try to rename/delete the windowdef.xml. Quote
pe3k Posted August 15, 2005 Author Posted August 15, 2005 Make sure you have the needed user rights in the DVBViewer folder. For the OSD try to rename/delete the windowdef.xml. <{POST_SNAPBACK}> How do I find out if I have all the user rights in the dvb folder? Should I try un-installing the DVBViewer completely? or is there something else I should do? thx Quote
pe3k Posted August 15, 2005 Author Posted August 15, 2005 I have deleted the windowdef.xml and it works perfectly now. I only have to fix the dissapearing scheduled program now.. Quote
pe3k Posted August 16, 2005 Author Posted August 16, 2005 so what should I do? should I uninstall the DVBViewer completely? or what are the solutions?? Quote
pe3k Posted August 16, 2005 Author Posted August 16, 2005 ok now I have fixed the problem by completely uninstalling and deleting the DVBViewer folder. The scheduled recordings remain now programmed in the scheduler even after turning off the program. Quote
