SKYSTAR 2 TV/DVB - SETUP
G3LMO
Hi guys......HELP
Have looked through FAQ's but don't seem to be getting very far:
Problem #1: When ever the PCI card is installed (2nd slot down from AGP slot) it blocks my other programs that require a .WAVE input from working (I get an error message saying: WAVE INPUT DEVICE NOT READY. Error code 32
Problem 2: On launching the DVB program I get an error message: NO SOFTWARE MPEG2 DECODERS ARE FOUND. MAKE SURE THAT YOU INSTALLED AT LEAST THE FILTERS WHO (THAT?) CAME ALONG WITH THE INSTALLER.
Problem 3: The HELP button on the program is not highlighted (therefore unavailable???
Any help much appreciated.
Thanks
Nev (G3LMO
Vale of Pewsey
UK
Sorry guys, should have said that the OS is WIN98 SE.
But think this must be very difficult questions, as although some 62 people have read the help message, not one seems to have any idea how to correct the problems.
Does your soundcard work in full duplex mode?? Otherwise change the output device to DirectSound.
That is, because you haven't installed any helpfile. (DVBViewer.chm)
For Problem 2 follow the Link above in Olivers post
Yes OK...........But where do I find that please? It does not appear to be on the installation CD :-(
  • 3 weeks later...
After ONE MONTH of trying, can't even get the OSD "HELP" button to highlight, never mind anything else. (What is DVBViewer.chm)?
Using here:
WIN XP PRO (Ver 2002) with SP2
AMD Athlon XP 1700+
1.47GHz 512MB RAM
PS: Thank heavens I setup a WIN XP "Restore Point" before I started hey?
which TechniSat drivers and software are you using with your card. If it is not 4.3.0, you should download this release from the TechniSat website.
Hi......
Yep sure is.
CD that came with card direct from Germany, is marked:
TV/Recording/Data Software
Installation software (v 4.3.0)
Network Adapter Driver details (Shown under Device Manager)
B2C2.inc
PCI Slot 2 (PCI Bus 0, Device 10, Function 0
This device is working properly
Driver: B2C
Date: 04/10/2004
Ver: 4.3.0.9999
Not digitally signed
Have also checked the Network Adapter driver details in Device Manager:
TechniSat DVB=PC TV Star PCI (shown as follows)
C:\Windows\system32\drivers\Skynet.sys
Is this correct please.
Other info.....................
That driver when "enabled" is affecting the speed that IE6 is connecting to the internet............appears to almost lockup the modem connection until "disabled?
Any comment please ? Possibly XP Firewall settings perhaps or what?
ALSO.........Do not appear to have a "Terrestrial" icon on the task bar........Just the Satellite (dish) icon, altho I appear to have gone through the complete "Install" procedure.
Any comments please
Regards
G3LMO
Vale of Pewsey
UK
Doesn't look like too much help forthcoming here does it?
What a pity there isn't a reasonable HELP folder/button (that actually works) following the install from the CD.
It seems that this program is not as straightforward to install as the advertising blurb makes out hey?
Surprise! Surprise!
G3LMO
Vale of Pewsey
UK
Seemingly you never posted the necessary information. We don't like guessing games.
Yep.....DVB sure is a guessing game.....You are right there. Most helpfull.
G3LMO
Vale of Pewsey
UK
As that is in German, it is no use to the international community what so ever I'm afraid. Not sure quite how it would answer the above questions anyway.
Nev (G3LMO)
Vale of Pewsey
UK
German??? Where??? Surely not in the link they warmly want you to read...
Please try to click on the link I repost here below and try to carefully read it: I'm assure you that's in plain english...
How to post bugs or problems correctly...
