CAM Menu Problem
markymark
I have problems acessing the CAM menu in DVBViewer. My card is a Twinhan DTV CI and I use an Alphacrypt Light CAM. The cam does a fine job decrypting, but I cannt properly access the menu. It doesnt seem to work at all. The only occaison when it works a LITTLE is when a program is protected by age ... the menu enables to enter the PIN if this happens right after DVBViewer was startet. Later on, the menu is unavailable, e.g., when I surferchannels and come across one where I would like to enter the PIN ... the menu is just empty then. It works fine in the original software ....
Regards, Mark
I have the same problems with DVBViewer 3.2.1 . My card ist a TechiSat Skystar 1 CI and I use an an Alphacrypt Light CAM.
Regards, htro
Edited by htro
