SS2 makes my computer crash
gonzaloblanco1992
Well just in case a merciful soul would care to help.
I have a AMD Athlon XP 2100+ 1.72 GH2 512 Mb of RAM and a TECHNISAT SKYSTAR 2 v2.6d PCI CARD running WXP S2
Having installed the updated drivers and programs my computer freezes and needs rebooting. It did the same with the provided CD drivers and programs.
Rebooting fails unless the card is disabled by entering safe mode.
The problem is not solved by installing other programs such as Mytheater or by changing the slot of the card.
The card was brand new, but purchased through ebay, so there you go.
Please somebody tell me that I am not alone in this world.
Thanks
maybe an IRQ-Konflikt. Try an other Slot.
Do you have an Asus A7V *** Board? I had a rev. 1.0 of this board and this work. But newer revision does not work.
I had the same problem without an solution. Now i use a twinhan in this board and it works well with DVBViewer.
Yes, you were rith it was a RIQ conflict. I had to eliminate a card I was not using anyway and now works perfect. Thanks for the reply
