Watching recordings
Jukka
If I record some program and try to watch it afterwards, it plays only couple of seconds. I've tried .ts and .mpg. In the record folder all .mpg:s are ok (when watching bsplayer). Even if I try to watch the video clip OSD -> hpPC -> Movies it plays only few seconds.
My computer: Win XP SP2, Radeon 9250SE, Thunderbird 800, 512MB ram.
edit: version 3.2.1
Here is setup files:
setup_txt.txt
MPEGDecoder.txt
DVBViewer.log
Edited by Jukka
I changed FileDvbSource and problem solved. But now is a new problem: When I start DVBViewer it starts in full screen and it's not possible to minimize. Also if I press right mouse button on screen, nothing happens. So I can't go to options menu. Here are new setup files:
MPEGDecoder.txt
setup_txt.txt
DVBViewer.log
<entry name="HTPCMode">2</entry>
Set this one to 0 and try again.
In Finland,
when recording output format is .ts and "use dvbsource for mpeg files" in direct-x setting are on and channel is Yle_Finland Tv1 or Tv2: when I watch what I've recorded, it's the same situation as on first post in this thread.
If I click "use dvbsource for mpeg files" in direct-x setting I get following error (attached): post-15469-1125694123_thumb.png
When recording output format is .mpg there is no problem but then I can't save the subtitles from Yle_Finland TV1 or TV2.
edit: card is Twinhan minicab cable.
DVBViewer.log
setup_txt.txt
MPEGDecoder.txt
Edited by Jukka
use tsplayer for this. you can get it in download area.
go to options and use DVBViewersource for playback...
