mustis Posted September 4, 2005 Posted September 4, 2005 How can I disable the "Exit: Are you sure yes/no" question in DVBViewer Pro 3.2.1? Besides, there is a bug in the question. For the first time, it asks, but if I answer no and try to close the program, it will close immediately without asking any more. Another question: when I schedule program recordings, why don't subtitles get recorded? And how can I play back subtitle recordings? Quote
Hartwig Posted September 4, 2005 Posted September 4, 2005 Du you use the DVB Task Scheduler?? Then update it to the actual version 1.8 Quote
mustis Posted September 4, 2005 Author Posted September 4, 2005 Du you use the DVB Task Scheduler?? Then update it to the actual version 1.8 <{POST_SNAPBACK}> Yes! It helped! Thank you! Quote
