newcredo Posted October 15, 2002 Posted October 15, 2002 ...installing version 1.95 can create any problem to the pre-existing 1.8d version ? Or both of them can run on the same pc ? Quote
Guest hackbart Posted October 15, 2002 Posted October 15, 2002 both can run on one pc, since i do not write anything into the registry and store each data in one folder they should not harm each other, theoretically you can even put them into the same folder (before this you should rename one of the two executables). Christian Quote
