problem with tuner on my skystar2 again
podroom
hi all.i'm new on this forum and i have a problem with my ss2.when i start DVBViewer i get the message:"Cannot set tunerstatus (wrong settings),Error :0x90010115(unknown error code)".
does anyone know anything about this message.
I have:duron1100 on Abit NF7-S,windows XPhome,radeon9600xt,ss2drver TS430,nforce 2 chipset...filters installed are:
MPEG2 Video Decoders:
Elecard MPEG-2 Video Decoder: 00800001
MPEG Audio Decoders:
Elecard Audio Decoder: 50000000
ffdshow Audio Decoder: 3FFFFFFF
MPEG Audio Decoder: 03680001
Driver? What kind of DVBViewer?
... and make a channel scan with update!
OK, rename your channel.dat. Start your DVBViewer and perform a channelscan.
Now this problem should be history
yes that problem is solved thx,but i still cant watchdvb viewer.when i perform channel scan it cant find any channels.same thing happends with prog dvb.I must say that when i scann astra on 19.2 it find few channels and repeat them on my list about 10 times.like this:
tv5
tv5
tv5
tv5...
then
zdf
zdf
zdf
zdf....
Is my card locked?
since driver 4.28 dont exist a lock !
can you try the cable with an other digital reciver?
If you recive zdf by scanning you should be able to view it.
that was just an example it dont scan zdf,but Ill try with reciever,and yes i can see found channels
Edited by podroom
ok, what you cant scan that you cant see. its quite simple.
Maybe you have to made some scans with transponder list?
Or how you have made a scan?
I've tried to scan astra 19,2(full scan),I even tried on another dish and lnb.First time when I turned on pc(on another dish and lnb) it looked like everything is ok(signal indicator went to green),but when i tried to watch some channels on DVBViewer it changed colour to red.I've tried with few different drivers(4.2.2,4.2.8,4.3.0)but everything is the same.Tried to install ts reader,to clear "B2C2" registry,to delete SkyStar.sys file in drivers folder(I've read it on this forum)but still no use.maybe my card is ready for JUNK...
Edited by podroom
