Can't tune with Pinnacle 310i DvB-T...
Awesoft
I'm trying to search channels with my Pinnacle 310i DvB-T, however I can set the channels only from MediaCenter, not DVBViewer.
I have set DVBViewer 3.2.1 from Options/DirectX/DVB File Device/Device: Terrestrial... then I go to "Channel/Channel lists" and I set "Terrestrial (EUR)" but can't find any channel.
Where is the problem?
Thank you.
Currently the DVBViewer Pro supports TV cards based on a B2C2 chipset or Twinhan devices.
What do you mean? Pinnacle 310 is not supported? wich is the 310i chipset?
That's correct.
I don't know. At least it's neither B2C2 nor Twinhan (some Conexant).
After dealing with some legal issues the DVBViewer Pro will support all cards with BDA-drivers, though - that includes Pinnacle.
