RaStr Posted September 7, 2005 Posted September 7, 2005 Hello, I have purchased DVBViewer recently and I am very satisfied with it, except two little glitches. I use DVBViewer Pro 3.2.1 and DVBViewer GE 1.6.1 with AVERMEDIA 771 and B2C2 wrapper. Fist problem is: in DVBViewer Pro in Teletext the language auto detected is Turkish instead of correct Czech (although in GE version it works fine!). If I select Czech language manually it works, but the selection is not kept after DVBViewer restart (is it possible to define default Teletext language in the setup file?). Second problem: Czech characters are not displayed correctly in the EPG lists (ISO 6739 encoding is used by the operator). My question is: will ISO 6739 will ever be supported and is possible to display EPG correctly when Latin 2 encoding is used in the transmission? (We have two operators here now, one uses ISO 6739 and the second one uses Latin 2 (ISO 8859-2) instead, both streams the same channels, so I can choose either of them). Quote
